Question about 505 Games Big Catch - Bass Fishing for Nintendo Wii
Line break with fish on - 505 Games Big Catch - Bass Fishing for Nintendo Wii
Go to options at the start screen and turn line break off
Posted on May 08, 2010
Is there a repair kit or solution to fix the rear windshield line that has cracked in two. It is located inside the door hinge.
No. best the cut the wires on the inside of both body parts and fish threw new line and connect them there. Fixing the break in the hinge part is a pain and doesn't last long.
Oct 07, 2016 | Cars & Trucks
Tip
Remove Motorcycle Tank Badge
Removing the "badge" (also referred to as the nameplate or label) from your motorcycle tank is very easy. No tools are required!
Did you know that badges are kept in place with adhesive? From start to finish the whole process will take less than half and hour.
The required "tools" are a hair dryer, dental floss or fishing line, adhesive solvent, some gloves, and a soft cloth or towel.tools.jpg
Turn on the hair dryer to the highest heat setting available. Either hold it yourself, or hang it upside down by the cord from your handlebar, leaving the hot air blowing on the badge for about ten minutes. Next, saw beneath the badge with dental floss or fishing line.flossing.jpg
Using a gentle sawing motion, continue all the way behind the badge.fishingline.jpg
Removing the residual adhesive is the most time consuming part of the project.badgegone.jpg
I recommend using Goo Gone or another adhesive solvent. It won't ruin your paint, but will weaken the adhesive. Use more solvent than you think will be necessary. The more the better. googone.jpg
Wipe with a clean, dry cloth and you're done! The final result looks great. Your tank is now ready for custom graphics or paint. finished.jpg
on Mar 16, 2009 | 1999 Honda F6 C Valkyrie
Which are the best places to do fishing?And which are best fishing rods we shuold have ?
Fish like edges or places where the bottof structure of the body of water you're fishing changes.
For instance a shallow flat with a deeper hole or ditch running through it. Or a drop off with a point that extends off of it.
if spots like the contain cover then they become even more attractive to fish. Cover is weeds, wood, rock or any other type of material that either naturally occurs of is artificially created. For instance a concrete break wall or a jetty that has bRosen rock along it makes great cover for fish. Fish also use edges, these can occur in a number of different ways. For instance where sandyou bottom turns to gravel or the edge of a weed line or where warme and cooler water meet etc. If you can locate an edge on a structural change and that edge meets cover or is the cover itself you've found potentially awesome fishing spot. The fish might not be there every day but they will use it at some point in time.
Hope this helps, good luck.
Nov 06, 2014 | Fishing
How to fix a fishing rod broken tip
I pushed my seat back and broke the tip of my good graphite rod.
The break was about 4" back from tip.
I fixed the tip of my graphite fishing rod with a sewing needle and a 3" piece of electric heat shrink.
The graphite rod is hollow in the center. Find a sewing needle that fits snug in the center. Put a piece of the smallest heat shrink over one side of the break and slide back out of way. Put some super glue on the needle and slide firmly on one side. (don't waste time.. super glue is fast) . Then put glue on the piece of needle that still sticking out and slide into matching side of break. Push together snug and make sure eyes are aligned. Slide the heat shrink over the break and heat with hair dryer till nice and snug.
Done. Fixed.
Aug 11, 2014 | Fishing
Steering wheel not able to turn the engine
Hi there. Check all the linkage that connects the steering column to the motor. You most likely have some binding or a break in the line that moves the motor.
Apr 25, 2011 | Boating
Need to change fuel line
I solved this problem by feeding a heavy weight fishing line through the hole in the tank. I then cut the fuel line at an angle, to give a taper to the end. I tied an angler's knot around the tapered end of the fuel line, and pulled it very tight to compress the line. Pull the fishing line back through the inside of the gas tank, taking the fuel line with it. Make sure you use heavy enough fishing line that won't break when you begin pulling. Reduced this to about a 30 second job this way.
Apr 07, 2009 | Poulan Garden
How to reel in a fish
To reel out push on Z on the nunchuk and continue to rotate nunchuk or push on B and Z
Jan 12, 2009 | Nintendo Rapala''s Fishing Frenzy for Wii
Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Nov 29, 2008 | Penn Gt Series Levelwind Reels 330GTi
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
505 Games Big Catch - Bass Fishing for Nintendo Wii Logo
266 people viewed this question
Top 505 Games Video Game Consoles & Games Experts
James Wishart
Are you a 505 Games Video Game Console and Game Expert? Answer questions, earn points and help others
