Question about Olympus FE-340 Digital Camera
Can i charge my camera from my pc? - Olympus FE-340 Digital Camera
Charge indicator
Perhaps you want to charge via a USB connector on your PC. Could be the PC connections are not correct for delivering 5V on that connector.
The manual also says:
Connect the camera directly to the computer; do not use a USB hub or keyboard.
Please try to charge via the external charger that came with the camera. If that fails too, please try to replace the USB cable.
Nov 09, 2013 | Fujifilm FinePix T400 Digital Camera Black
Panasonic Lumix DMC-ZS15 will not connect to pc and will not charge. Bad card on camera?
Are you turning the camera power on when you attempt to charge the battery? The camera power needs to be "OFF" when charging. When connecting the USB cable to your computer the camera must be "ON" and in the "PC" mode. Hope this helps.
Sep 04, 2013 | Panasonic Lumix Dmc-zs15 12.1mp Digital...
How do you charge a nikon coolpix s3000?
It comes with a wall jack that powers the included USB cable. Plug the USB cable into the wall jack and into the camera to charge. You can also charge from a PC if you connect the USB cable to the PC instead of the wall jack.
Dec 26, 2010 | Nikon Coolpix S3000 Digital Camera
I cant find my charger and software for vivitar 8025. Is this something I can buy online separate? Does USB cord charge camera if plugged into pc?
The USB cable does charge the battery if plugged into pc.
The red LED will light while charging and go off when the battery is charged.
I cannot find any options to buy the software online but the Support email is: support@vivitar.com
Hope this helps.
Feb 19, 2010 | Vivitar ViviCam 8025 Digital Camera
IF I CHARGE MY CAMERA ON MY PC DO I NEED TO PUT IT ON AND LEAVE IT ON AND TILL CHARGE ... I HAVE A VIVITAR VIVICAM 8225..
Is recommended that you do not use a pc to charge your camera. Instead use the supplied power supply.
Also, please note that when charging your camera you should wait until it is empty (or almost empty) and then charge it fully. This will ensure a longer battery life.
Feb 02, 2010 | Vivitar V-8225p Digital Camera
I have the EASYSHARE M1033 Digital Camera
Mine did this as well. I now have it plugged into my PC with the usb cord. I think the ac charger that came with the camera is not functioning. Try charging it from your PC.
Aug 01, 2009 | Kodak EasyShare M1033 Digital Camera
My logitech 130 camera's not charging properly
http://www.logitech.com/index.cfm/480/3398&cl=us,en?WT.ac=sc|downloads||dd
Jul 19, 2009 | Logitech Pocket Digital 130 Digital Camera
My 24280 dig. Wont charge
the pc function means that it is connected to your computer this is good because now you should be able to upload pics and ect...the red light is simply to show its charge level and is always on when plugged in to computer also there should be a switch on the side to change from camera to charge if its on charge and the light is red then its carging and it will turn green when its done.
Jun 16, 2009 | Sakar 24280/24282 Digital Camera
Olymous FE-150 Camera charger
Dear customer,                    Its not possible to charge your camera via pc. You have to get a new charger.
May 07, 2009 | Olympus FE-150 Digital Camera
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
Olympus FE-340 Digital Camera Logo
82 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
