Question about Honeywell HZ365 Ceramic Compact Heater
Help me please
I have a Honeywell HZ365 Cermic Portable HEater and have no clue how to use the thing does anyone have an operators mannuel they can email me
  • 4 more comments
  • summercamper Nov 02, 2007
    I have the same problem - I don't have a manual to know how to run my Honeywell HZ365 Ceramic Compact Heater. Are there any manuals online? I have gone through the Honeywell site online and when I search for the HZ365 model it says they don't have one?? My e-mail is if you can help with a manual.
  • TJV1 Nov 08, 2007
    When we picked up the heater to move it from the counter to the floor, it turned off. We have not been able to get it restarted. We have had it unplugged for days and nothing happens when plugged in. We don't even seem to get any power to the unit. Any suggestions would be wonderful! We borrowed it from a neighbor and have no manual. Thank you!
  • cindyo1228 Feb 23, 2008
    I need a manual to set the heater and cant find one online .my email is or
  • Anonymous Aug 03, 2008
    I need a Manual.
  • maklein55 Nov 22, 2008
    Anyone know where I can get a manual for it.
  • hlangley Dec 27, 2008
    I lost my manual a long time ago and need operating instructions. Please let me know where to find a manual or send information to
We want to know haw to use it
Posted on Sep 20, 2008
Honeywell portable heater HCE322V manual
Honeywell has the manual for the HCE322V ceramic tower heater on the product page: . Click on the Manuals tab. The direct link to the manual is .
I hope this helps. Note: the manual covers a few different models. You should ignore any section about the HCE323; that model has a remote and a few other extras.
Jan 08, 2017 | Honeywell Heating & Cooling
I'm searching for a Honeywell HZ365 ceramic compact heater to purchase
this one is similar...
Dec 02, 2012 | Honeywell HZ365 Ceramic Compact Heater
This heater sits for a year without use and now I can not turn it on. Does it have multi-button reset to turn it on again?
These types of plug in portable 1500 watt or less heaters use fusible links, limits, safetys etc some of which dont auto reset, many times failing due to one of these essentially non servicable components,I have several times taken these various defective heaters apart, rarely unless an older better built unit, have I seen fan motors fail, nor heat strips, 90% are some safetys/limit, the rest are the switch. unles you can bang or tap it to come on its through. I myself hack the heaters bypassing the failed part, often running them direct , no limit, fusible link or even switch, only to use them in situations where I wont sleep or leave the area, as there is zero safetys now! i do not recommend this to anyone except a technician, i have several motors and coils hanging by the cords running sans their plastic housings a naked heater, they work for years this way so clearly the limits/safetys are the weak pots on these units, by design I suspect.
Dec 16, 2010 | Honeywell HZ365 Ceramic Compact Heater
The main on/off switch is defective... Where can I purchase another one? Honeywell portable heater HZ-515
dear sir /madam
please find out heater unit company,s dealer at your area you can purchase that switch or you contact to your maintenance personnel for further action .i mean replace your defective switch.
hope answer the question
please vote
thank you!
Sep 05, 2010 | Honeywell HZ-515 Baseboard Heater
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
I'm assuming that this is a portable heater. If not let me know. If it is it sounds like the heating coil is bad or the relay which turns on the heat is not working. TU probably means turn up the thermostat. I guess you could try that but it seems pretty obvious. Let me know how you make out.
Feb 10, 2010 | Honeywell Programmable Thermostat Heater
Portable honeywell wont turn on
the thermostat is a variable rotation type. turning it in one direction varies a gap on a set of contacts mounted on the inside of the front panel. take the heater apart by taking out the four screws in back. the front panel should come off and you'll see the thermostat contacts. rotate the knob and see what the contacts do. if they make up, your element might be shot.
Nov 04, 2007 | Honeywell Electronic Ceramic Heater
Heater kicks out
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Sep 19, 2007 | Honeywell HZ365 Ceramic Compact Heater
Honeywell HZ365 Ceramic Compact Heater Logo
260 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
