Question about Sony Ericsson Cyber-shot C902 Cellular Phone
The phone was dropped and seems to be dead
I tried a different battery with no success. A local phone shop connected the phone to a PC and said it seems to be completely dead. I thought I might try to open it up to see if there is anything obvious before deciding whether to get it repaired but I can't find out how to open it. Can you tell me how?
  • will_dobbie May 14, 2009
    Thanks for the advice. Very sensible.
    Scholar:
  • 106 Answers
Here is the disassembly guide for the C902
http://www.formymobile.co.uk/c902disassembly.php
However, its not very likely you will be able to see anything wrong, if there is an IC loose or missing you will not be able to replace this, without a very fine soldering iron or a rework station, if you damage anything further then it will cost you more in the long run and if you have a warranty still then it will void that...
If the phone is still under warranty, I would try a proper SE warranty repair centre, if your in the UK try one of the larger CPW stores, if they themselves are not a SE repair centre they should be able to point you in the right direction of one. Dont mention that you dropped it, as long as its not water damaged they should be able to repair or replace the handset for you for free :)
Posted on May 14, 2009
  • c9679 May 14, 2009
    No problem mate :)
Hi My LGLX130 Wont switch on, what do i do? not sure if iy is the battery dead or the charger dead or the pc itself.
Can you not try a different charger? A local repair shop should have a universal charger that you could try.
Mar 02, 2015 | LG X130 Netbook
My nokia 7230 does not power on what can i do
if the battery is dead try charging with a different charger,or better still go to any phone shop in your local high st, see if they can pin point problem,im thinking battery but could be the handset, more info on what you have already tried would be helpful.
May 27, 2014 | HTC Desire Cell Phone
My blackberry curve 8520 is dead, the problem is an application that ask for permisions but the windows never dissapear and i can´t do nothing with my phone even connect to the blackberry desktop
If it is indeed 'dead' then it is not going to be doing much. :)
I would try pulling the battery first. Letting it set for 5-10 minutes without the battery. Then plug it in to power without the battery and try turning on. Let it power on all the way if it can. Then power down using the power off button. Put battery back in. Turn on. Plug into PC with cable. Check if it can sync. If it does not power on, your first statement is correct, it is dead. You might check wth a local repair shop to see what the issue might be, unless the phone is under warranty or you have insurance.
Sep 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
I have this phone and the battery will drop from a fully charged state to dead and i have to recharge is there something i can do to keep this from happening
The best thing to do is take your phone and charger to your local network suppliers shop.
1.try a new battery if thats ok problem solved.
2.try charging with a different charger..if thats ok problem solved
3.If itsnot the battery or charger then the problem lies with the phone ..ask for a replacement at this stage.
Hope it helps.
Dec 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Can't resolve a W010 connection error
Let put all not IP Address in Obtain. I put all IP ADDRESS manually. Usually this will cause to your internet connection drop. I encounter your problem before but i use DUAL WAN or 2 Internet Provider.
And i hope it's the same problem to me.
Aug 29, 2009 | Actiontec GT704WG Wireless Router...
Nokia 6300 cannot be detected by my computer when
The PC seems to be OK. The phone switches off and hence can not be detected. You cant detect a dead device. Try a different battery. Or try using the charger while connectiong. If it does not go off then the battery is at fault. Change it. If nothig is detected faulty, then uninstall PCSuite . Restart the PC and re-install PCSuite without connecting the phone. When you connect the phone afterinstalling the SW, he phone will be detected immediately.
Aug 05, 2009 | Nokia 6300 Cell Phone
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Dropped
Erm, maybe because you dropped it.. just guessing. Anyway cellphones as other hi-tech appliances are very very touchy on the subject of handling. You can drop your phone from the 3rd floor and and still be able to use it and you can drop it 50cm and it'll be broken beyond repair. In your case something might have burned out or a connection severed in either case your best bet is repair if you have insurance (drops aren't covered though) or buy a new one. P.S. You can also try dropping it again if there is nothing to lose...
Jul 25, 2006 | Nokia 6230
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
173 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
