Question about Hotpoint Aquarius WMA42 Front Load Washer
Washing machine isn't moving beyond first setting
The macine isn't heating up and gets stuck on the first setting. If I click the setting knob round it will continue and finish the cycle. It is a Zanussi FJ831 Jet system. I would really appreciate any ideas!
Thank you
  • mary_j_saund May 16, 2009
    Thank you ike joe.  Although I don't understand what to do because I'm not an engineer your advice has given me hope that the machine is fixable, so I will call out the engineer.
    Many thanks
  • 56 Answers
Your machine is waiting at the thermostop position on the timer till its hot enough as per thermostat/timer temp setting,its probably faulty element or faulty stat ,id check the element first,it should have approx 20 to 35 ohms depending on wattage of machine,check element connections and heavy connection wires at timer for any burnt connections-hope this helps
Posted on May 15, 2009
  • ike joe May 16, 2009
    hope u get it sorted without to much cost
Washing machine not selecting cycles. It is stuck on fast wash, dial moves but wont click and select any other cycle.
Hi
the problem is the shaft on the control knob
is cracked so the knob turns but won't grip
the shaft on the control panel
requires an new knob
Jun 06, 2016 | Hotpoint Washing Machines
Frigidaire
The easiest thing I\'ve found was to use a marker and just put a line on washer where the cycle you use most starts.then with pliers pull that knob off, it may be amatuer but use pliers to turn the round metal small knob holder to start the washer. Use the mark on washer to know where to start and just guess at other settings that aren\'t marked,it\'s not difficult to figure out the others
Jul 01, 2013 | Washing Machines
Washing machine
I had thi problem.I removed the heater element but there was nothing wrong with it when tested .Do not do this as it is hard to get element back in
What I done was remove the top of machine and pulled connector of temperature knob It was corroded.I sprayed the connection with WD40and shoved it on and off a couple of times and hey presto it worked .Themachine is heating again
May 05, 2013 | Indesit W 123 Front Load Washer
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
regards
shaun
Mar 13, 2011 | Indesit W 123 Front Load Washer
The temperature knob on our ZWF14170W washing machine is stuck on 90C. My wife only turned it round to clean the knob and now it is stuck fast. I have tried to turn it back but am afraid of breaking it off...
There is a clip on your timer know in behind the knob itself. You got it miss align when your put it back and there is nothing there to hold in place.
Dec 05, 2009 | Zanussi Washing Machines
All my programs on my washing macine won't work apart from p1
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 04, 2009 | Washing Machines
Will not fill with water
It sounds like the pull-out switch, under the pull-out knob, is not working and may need replaced. Go to Repairclinic.com and type in what your washing macine is not doing and they will give you hints on what to do next. But, it sounds to me like that is what is wrong with your washing macine.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
MY KNOB KEEPS CLICKING ON A INDESIT WI141 WASHING MACINE
clean out the filter which is under the kickplate on the bottom right of the machine. HOpefully this should fix it.
Jun 09, 2008 | Indesit Washing Machines
DRYER NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Apr 22, 2008 | Equator EZ 3612 CEE Front Load...
Zanussi Fla1201w not heating water
Sounds like you need a new heater. test it with a meter to see if its open circuite. the programme will not move round if the heater is gone. heater cost around 20 GBP. to have an engineer do it will cost around 50 GBP.
Nov 18, 2007 | Zanussi FLA1201W Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
114 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
