Question about KitchenAid KIRD861HSS Kitchen Hood
I have a kitchen aid gas stove with a downdraft
I have a kitchen aid gas stove with a whirlpool downdraft vent that raises out of the counter and I do not know how to get into it to clean it. The odor of old grease is starting to overpower my kitchen.  I regularly clean the filters.  How do I clean the inside of it?
3 Suggested Answers
SOURCE: Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Posted on Nov 25, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: i think i have a
Sorry to read about your problem, I hope this helps you out.
you can purchase range top glass cleaner, at most grocery stores, or buy soft scrub...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
Whirlpool SC8720EDB cooktop stove independent vent switch is not starting downdraft exhaust fan, but the exhaust fan works fine when left side burners were turned on
Can you get to the switch terminals and try jumping them out with a piece of insulated wire? That would tell you if the switch is defective (my suspicion). Please be careful not to touch any live terminals - only the wire insulation you use for the jumper.
Aug 02, 2017 | Whirlpool Cooktops
The self clean feature stops part way thro the cycle and knocks out the oven entirely. The gas stove top still works
Kitchen aid (now Whirlpool) has actually produced a defective stove here. Your problem is the thermostat in the rear of the unit. You can replace it yourself if you are handy, but that will not fix the problem that is built in to this very poor quality stove. If you ever try to use the self cleaning feature, it is most likely you will overheat the unit, and knock it out again and again.I wrote to Kitchen aid and received a very rude response from their "customer dis-service dept"...I told them theyir stove was defective and they wanted to sell me a NEW part for a high price, not even saying "sorry"...what a bad company! I urge all to stay away from Whirlpool products...they are junk!
May 22, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
I would like to put my cook top on an island in the centre of my kitchen how would i vent down thru a crawl space???
Get a downdraft cook top and drill a hole. Then run the piping to the outside wall of the house and drill again and run the piping thru to the outside. They make outside wall vents like dryer vents only bigger to accommodate the bigger vent pipe. Happy crawling. It will look and work great if you get a good stove. Do your research.
Sep 01, 2010 | Electrolux Icon Downdraft Ventilation...
Apr 03, 2010 | KitchenAid KIRD861HSS Kitchen Hood
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
The glass cook top of my whirlpool range cracked and i can`t seem to find a model number anywhere on the unit. help
You might find the tag in one of these places:
Cooktop/Range/Stove
Gas:
  • Inside the cooktop--if the top lifts up
  • On the outside, bottom of the unit
  • Inside the top of the vent duct--if it's a “downdraft” unit
Electric:
  • Under one of the surface burners, or inside the cooktop--if the top lifts up
Gas or Electric Oven
  • On oven side of the door jamb (with the door open)
  • On the lower drawer jamb (with the bottom drawer open)
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Kitchen Ranges
Kenmore elite 36" downdraft dimensions
I am using it on an island... it has a 6" high backsplash with a counter on top. How can we make the downdraft work with it?
Mar 11, 2009 | Kenmore 59940 Kitchen Hood
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
KitchenAid KIRD861HSS Kitchen Hood Logo
158 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
