No sound for my tv, picture is ok, speakers ok.
  • 700 Answers
Start to check if it is in mute or volume is in 0 level first. Or check also its sound source setting. If this does not help check the electronic side.
If speakers ok, check wires to it. This will also down to the amplifier side after the wiring and speakers are ok.
If you are not inclined in electronics, have it service by a qualified one.
Posted on May 14, 2009
The sound on my tv is just clicking
First, try to connect ext speakers. If the sound is OK just replace speakers. Otherwise the problem in amped sound output.
Feb 09, 2015 | Samsung HLN567W 56" Rear Projection HDTV
Tv has picture but no sound
Check its speaker/s. If OK, check and replace damaged component/s at its audio output section circuit. For more details
Nov 25, 2013 | ViewSonic N3735W 37 in. LCD TV
Sony 32" trinitron perfect picture, but no sound
Check its speaker first. It sounds that the speaker is out. If it is found OK, check for any loose solder terminals at the audio output section circuit, of damaged component/s there.
Sep 15, 2012 | Sony FD Trinitron WEGA KV-27FV300 27" TV
I have no sound on my LG32LB9D
Hello
You haven't specified anything about the condition of picture. So I thinks there is no sound; picture OK; and posts this solution. Check out the speaker first. Just place your ear very near to the speaker side of your TV and switch the TV 'ON', by using its main power ON/OFF control [Not with remote control handset]. If you can hear a 'thumb' sound from the speakers the speaker is OK, and the sound output section inside the circuit board of your tV is faulty. Either sound card or audio output IC may be replaced. If you can't hear any 'thumb' sound when you switch ON your TV, the speaker is faulty. Replace the speaker with samee type and impedence. Its impedence will be marked on its magnet [in terms of Ohms]. OK.
Jul 01, 2011 | LG Televison & Video
There is no volume
Hello
Your Astar TV has no sound and picture OK I understands and posts this solution. Check first its speakers. If speaker is out there will be no sound output from the TV. If speakers are Ok, the sound card is defective and need replacement. You can check speaker with the use of a multimeter. Set the multimter to Ohms range and check the resistance of the two terminals of the speaker. It should be between 4 to 8 Ohms. If not, speaker is faulty and should be replaced. As in the case of sound card, it is a skilled work, and cannot be done by the user. OK.
May 29, 2011 | Astar LTV-32ASB 32 in. LCD Television
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
No sound
Hello
You haven't mentioned about the picture at all. Assuming that, picture is ok I suggests. Ok
If the picture is Ok and there is no sound output from the speaker, your TV has either speaker problem or output Ic problem. To assure where is the fault, you just place your ear very near to the TVs speaker side, and switch on the TV. If you hear a "thumb" sound or a "HUM" sound, your TVs output ic has blown out. If you did not hear any sound at all, the speaker of your TV has gone.
If you have a little knowledge in electronics, you can do it by yoursef. This is a minor mistake. Opwen the back cover of your TV, locate and note the type and number of the audio output Ic, go for that and get it replaced; if the fault is related to Ic. You can do the speaker replacement also by this way. I have given this much advice, assuming that picture in your TV is Ok. Otherwise the fault may be different.
Oct 20, 2010 | Bush Televison & Video
Their is no volume
Hello
There is no sound you means? If so what about the picture? If picture is ok and there is no sound either the speaker of your tv or audio output Ic inside your TVs circuit board is faulty.
To check it, place your ear very close to the speaker side of your tv and turn it on. if a "thumb" sound or a "hum" sound is heard from your TVs speaker, the output Ic is faulty. If there is no sound at all, speaker is faulty. If you have any home theater system; and your TV has audio out RCA sockets at the rear or front side of it, connect it to audio system, and swich on both and find if there is sound output or not. If yes you can assure your TVs sound filtering system is ok, and the fault is somewhere between speaker and audio output Ic. Ok.
Oct 19, 2010 | RCA F20640BC 20" TV
I have picture but no sound on my maxent plasma tv?
Check your mute control off/on status. If OK check speaker. If speaker is Ok, it is a sound IC problem. Contact service center.
Apr 20, 2010 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
