Question about HP iPAQ hw6515 Pocket PC
I need a battery charger for hw6515f - HP iPAQ hw6515 Pocket PC
  • HP Master
  • 13,433 Answers
Heres one on ebay, if its not the right one for your country then look for another one. for example on ebay.
Click here, ebay deal.
Posted on May 22, 2009
Hello I need the 14 volt 1000ma barrel-end charger for the Kalee Fire Truck. 40029 I can't get it anywhere
One of these. Here you go
Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery ...
https://www.saretailinc.com > RideOn and Toys > Replacement Parts Best price for Kalee14v_BatteryChargerBarrel_1000mA Kalee 14v 1000mA Battery Charger (Barrel End)
Amazon.com: Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys ...
https://www.amazon.com/Kalee-1000mA-Battery-Charger-Barrel/dp/B016V5Q1EG Amazon.com: Kalee 7.5v 1000mA Battery Charger (Barrel End): Toys & Games.
Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma ...
www.bestscooterbuysstore.com/kalee-14-volt-battery-charger-2-prong-12-volt/ Kalee 14 Volt 1000ma Battery Charger (2-Prong) Kalee 12v 1000ma Charger (Labeled 14v Charger) ... Kalee 12v 1000ma Charger (Labeled 14v Charger). This item usually ships ... Mini Motos 12 Volt Barrel-End Charger $31.99. Kalee 6v ...
Oct 23, 2017 | Cars & Trucks
What volt charger do i need to charg mower 12volt battery?
Doug, Any 12 volt automotive charger will work for your lawn tractor, the cheaper no frills chargers will work fine.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Battery Chargers Canadian Tire
Amazon com Battery Chargers Jump Starters Battery Chargers Portable Power...
Car Battery Chargers
Feb 27, 2016 | Cub Cadet Garden
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Need battery charger for robust 18v drill/driver. charger model 9706
need battery charger for robust 18v drill/driver. charger model 9706
I have exactly the same charger with the battery .
my drill is fallen , and it is broken .
Jul 13, 2010 | Drills
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
I have a new PC and have lost My iPac hw6515f startup CD. It can't comunicate with my PC. How do I get it to comunicate and manage things like the appoitments etc.
go to the HP web site, click support. you should be able to download what you need there. if HP does'nt help download activesync for your model. hope this helps.
Oct 30, 2009 | HP iPAQ hw6515 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
