Question about Dell Latitude D600 Notebook
Dell d600 would not power up, some lights flash for few seconds and goes off. if i press esc button the fun runs but the comp does not turn on. please advice what to do.
    Problem Solver:
  • 10 Answers
Either try; ctrl+alt+delete, F1, F2....., or mess about a bit
Posted on May 14, 2009
I have trouble booting up my Dell Latitude D600. When I press the power button status lights on right flicker for few seconds then shut off.
try removing the battery (keep ac power), test
if nothing, try the opposite,
remove both ac power and battery test,
for some reason holding down f10 and cursing at the machine seems to help. Mine does this but typically will boot after a few attempts (and lots of cursing)
Sep 12, 2011 | Dell Latitude D600 Notebook
Dell D600 won't boot
I am sure Not the CPU or fan problem. Follow the below step to repair it.
1. Just press the power button 5 seconds or more to see the laptop can reboot or not. 2. replug the memory modules. 3. maybe the power supply device failed that the electronic volt is not enough to boot the laptop. Just replace a new Dell latitude d600 battery power supply.
Jul 28, 2010 | Dell Latitude D600 Notebook
My Acer Aspire One boots up but only runs for 5 seconds then click, and it goes blank. It has a charged battery and does this even when plugged in to the charger. I have tried to boot it up using F2 and...
hi there,
use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
Jul 11, 2010 | Acer Aspire One PC Notebook
My acer aspire 4315 laptop screen goes dark
ASPIRE ONE BIOS FLASH RECOVERY
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
http://support.acer.com/drivers_download.aspx
http://blog.shimpossible.com/2007/07/18/white-screen-of-deat­h/
Mar 05, 2010 | Acer Aspire 4315 Notebook
My harddrive light is not on and the power will not shut off on my acer netbook aspire one There is absolutely nothing on the screen as well. It was up and running and it just appears to have givin up the...
Oct 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dell Latitude D600 Boot problem
Weak battery, bad power supply adapter cable, and/or a dirty power switch can cause this problem.
Sep 19, 2009 | Computers & Internet
Dell d610
remove the memory and make sure that the contacts are clean, then be sure to replace the memory correctly & power up as when you power up & the light flashes before boot up this is usually a memory problem i have found with my d600
Jun 15, 2009 | Dell Latitude D600 Notebook
My acer aspire one netbook was black screen but the power was lighted, i hear the fun was spinning and the hdd was spinning, please help me, when i powered on it lights up but no display at all a blac
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
May 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Dell D600 latitude will not power up
you can try to replace the motherboard, which is apparently totally UnHappy
Mar 16, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600
remove the battery and adapter..keep the power button pressed for 10-15 seconds....again plug in the battery\adapter and turn it on...
Feb 08, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
