Question about Gateway (4000444) Motherboard
Does anyone have a pin out drawing of the Gateway 6MSB Li-ion battery pack please
Tip
Sony NP-BG1 battery|Cheap NP-BG1 digital camera batteries
New,1100mAh, 3.60V, Li-ion, Sony Battery Pack
  • Chemistry : Li-ion
  • Voltage : 3.60V
  • Capacity : 1100mAh
  • Dimension : 41.90 x 35.40 x 8.10 mm
  • Color : Black
  • Brand : Sony Digital Camcera Battery
Replacement SONY NP-BG1 Digital Camera Batteries, Li-ion SONY NP-BG1 Battery Pack
on Jul 20, 2010 | Cameras
Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Aug 23, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
My laptop battery is not charging properly??? what should i have to do?? plz!!!!!!!! reply
We need mark and model and date of purchase. It could be that the battery is worn out
Jan 17, 2011 | Computers & Internet
My Kodak Easyshare Z1275 has short battery life. sometimes even newly charged 2600 MaH batteries cause problems. Powers up, lens extends, opens screen to set time and date then powers down. Sometimes i can...
wait, do you have Li Ion batteries or Ni MH?
I think that Kodak recommends Li Ion batteries which have a higher voltage on them.
I got some generic Li ion battery packs off of Amazon.com, with better specs. than Kodak, and they work fine for my Easyshare z1485 IS camera.
It cost me like $80 to get the charger and two battery packs that are Li Ion, but it's worth it.
My battery packs are rated at 2000 mAh 3.7 Volts each. It's the voltage that counts. You see, if you would split that in half, the voltage for each AA battery is 1.85V which is much higher than the 1.5V that regular Alkaline or Ni MH batteries are rated at.
I tried Alkalines, and Ni MH to no avail. But, the Li Ion batteries, did the trick for me.
Good luck on this 'repair' or battery upgrade.
Jul 23, 2010 | Kodak Cameras
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Li ion rechargeable Battery pack DC 10 8V 7200mAh is old
Contact BatteryRefill.com, they will rebuild your battery at a fair cost, compared to buying a new one.
Feb 17, 2009 | Getac A760S PC Notebook
Battery charger just flashes to say the battery has to cool down but will not start charging.tried another charger same thing happens but does not show that the batteries are faulty!
Unfortunately, Makita’s li-ion battery packs have a design flaw. After having the same problem with my two batteries, I took it apart and saw the problem immediately. You see each battery pack has ten li-ion battery cells and a circuit board with a memory chip witch holds the charging history of the battery pack. But that memory chip constantly draws power from 2 of the 10 batteries. The current it draws is very small but if you consider it over 6 month or more, the power drain becomes very significant. You end up with a battery pack with 8 still fully charged battery cells and 2 drained battery cells. When you put this battery pack in the charger, it detects weak battery cells, assumes they are defective and refuses to charge. To avoid this problem you should charge your battery pack often, even if you haven't used it, every two months should be ok.
I suspect that Makita doesn’t make these battery packs, they make power tools, good ones too. But Makita should definitely have a few words with their supplier before they become a liability!
Jul 03, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Gateway (4000444) Motherboard Logo
242 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
