Removing base how do you remove the base so i can wall mount it AWA(81cm)full HD television LC-32G76
  • 187 Answers
There are 4 screws on the back of the TV just above the base stand, remove those screws and then you can slide down the stand and remove it.
Posted on May 27, 2009
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
HOW DO YOU REMOVE THE BASE ON A 42" FLAT SCREEN
you will have about 4 -7 screws on rear of tv ... normally there a bit bigger than rest ...
Feb 27, 2011 | Sylvania LC-321SS9 32 in. LCD TV
My Awa lcd tv model LC-32G76 will not power on. It is on at the wall socket, but no lights are on the TV, nor will it turn on. It was working good last night, this morning I have this problem What is...
Check the Socket make sure that it has power plug a cell phone charger into it to check, if that doesn't work check all connections on the TV also try the remote to power it on if that doesn't work try the power button at the TV if that doesn't work try the input channels.
Jan 23, 2011 | Televison & Video
How do you remove the base from an AWA LC32G78 LCD TV in order to wall mount it?? I can't find anything in the manual.
normaly has on rear base plastic (nerby where cabes connectors), with a small screw to show another screws atach on the base, take this out to realease base. and find a extra plastic to cover where the base attached.
Nov 01, 2009 | Televison & Video
Removing television base
You will need a phillips head screwdriver. There are four screws on the back of the TV that go into two rather long "legs" that go a few inches into the bottom of the TV. Just remove those screws and lift the TV off the stand. If you have your owner manual it will show you exactly where the screws are located otherwise just look for the heads of phillips head screws.
Mar 20, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
Removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Apr 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
HELP PLEASE!!!!!
There are two handles on this set that come off with the removal of two screws. The base has posts that slide in up from the bottom. Trace the legs up and remove the two screws that hold each leg. You need a second person to help lift the set from the base. Now mount to the wall bracket.
Jan 20, 2008 | HP PL4245N 42 in. HD-Ready Plasma...
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Televison & Video Logo
970 people viewed this question
Top Televison & Video Experts
Electro Med Services...
