Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
Lost locals thru multiswitch
When I connect my sat inputs through a multiswitch to utilize my second tuner, I lose my locals.  The auto setup no longer detects the 119 and 110 degree satellites.  It detects the sats fine when not run thru the switch.  I've also shortened the distance the cables run from the dish thinking it was a signal fade problem to no avail.  I've used this type of multiswitch before with other receiver with no probs.  Is my multiswitch bad, or am I missing something?
  • zerstoiten Oct 16, 2007
    I have a 3 LNB oval dish.
  • 979 Answers
Do you have at least a 2-channel LNB on your system?...accordianman
Posted on Oct 15, 2007
How to change channel from one to any one channel in sony bravia
I need more info. Are you using antenna connected to RF input or are you using cable box, sat box or ATT Uverse? If connected to antenna . go in menu or Home on Sony. Press setup and look for channel scan. Set to antenna and do auto scan. If cable or other provider box set tv to ch 3 or what ever provider says. You are then using the tuner in that box. You will use providers remote to change channels. Be sure in setup that tv is set to cable if cable box is used. Hope this helps but the info you posted could be more descriptive.
Oct 02, 2013 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Plasma tv connections
What you need is a device called a multi-switch. Here's a page which details some of the switches available with different satellite setups. You would hook up your sat recievers, your TV and your recorder up to the multiswitch:
http://www.satellite-connection-systems.com/Multiswitches.html
Jan 08, 2008 | Computers & Internet
We lost local tv from Dish on one of the local channels. We want to use the TV (model LC-46D85U) to view the local channel. How do we get the TV to view in local over the air instead of the satellite. ...
Connect air antenna to RF(coax) input of tv. Go to the menu and look for channel setup.Select antenna and auto scan. When done scanning you should have whatever stations you are able to pickup. Connect Sat reciever to one of the other input on the tv. Then go to INPUT or SOURCE on remote and select tv for local and what ever input you sat box is connected to for dish.
Mar 07, 2011 | Sharp Televison & Video
How to program for sat
You do not need to program the TV for SAT because your signal comes directly from the SAT, you are only using your TV as a monitor, not a tuner. Connect your SAT via standard rca, component, or hdmi cable and change the input on your TV to the same input that you have connected your SAT to. If you connect via coax cable then set your TV to channel 3 or 4, ALWAYS using your SAT remote to change channels for both options.
Mar 03, 2011 | Televison & Video
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
TV ''Dish'' not working on second TV
check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Apr 23, 2009 | RCA DISH Network(r) 311 Satellite System
Want to use my old dish set top as dtv tuner
The antenna ports on these receivers are only analog pass thru's they will not convert to digital.
Nov 16, 2008 | DISH Network 301 DTV Receiver
Lost the cable signal
ok you hook up dvd to what input... you hooked up sat on what =input.. do you have old vcr around.. try hooking cable to vcr and in a sense use its tuner to tune with . this will tell you if your tv has a bad tuner... just hook the vcr to the same input the sat or dvd player is on
May 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Seting up the digital seems to be a problem, tv is tuned in, put digital doesnt? samsung 42" lcd plasma
First I need to know if you have a digital quam tuner in the set? If you don't you will only get analog thru the tuner. You must use a HD box from your cable co. or sat. provider to receive digital channels thru your component input.
May 08, 2008 | Televison & Video
Only get about 4 channels
Make sure in the on screen menu that the tuner is set for CABLE or AIR depending on whether you have cable or an antenna. The channel frequencies are the same for ch 2 thru ch 13 but everthing above that is different depending on your source.
Hope Ya Fix It!
Feb 08, 2008 | RCA TruFlat 27F520T 27" TV
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
125 people viewed this question
Jerry Greenberg
Jerry Greenberg
