Question about Intel Motherboard
No power in the mother board requesting for the
My ohone no, 9869400382 pls contac me
  • Art Ellison
    Art Ellison May 11, 2010
    Please describe your problem. Are you saying the motherboard is getting no power?
    Is the power supply working?
  • 33 Answers
NO POWER.
    Switching power supplies (the most common used PC's), cannot be adequately field-tested with V/OHM meters. Remember: for most switching power supplies to work, a FLOPPY and at least 1 meg of memory must be present on the motherboard. If the necessary components are present on the motherboard and there is no power:
      1) check the power cable to the wall and that the wall socket is working. (You'd be surprised!)
      2) swap power supply with one that is known to work.
      3) if the system still doesn't work, check for fuses on the motherboard. If there are none, you must replace the motherboard.
thanks
Posted on May 15, 2009
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Required mother board service manuals
What you are requesting is a chipset driver which is usually an executable file that can also be provided by the motherboard manufacturer. There are no chipset manuals nor component-level manuals unless you are an engineer that is designing a circuit. The bios set up is accessible at boot (post) by looking at the lower left of the screen where it will instruct you to press F2 or Delete or F10, etc. No matter what your language it should be apparent to provide model numbers and brand names. Try mailing a letter without an address or going to MacDonalds and ask for food. Would you be surprised that you received a blank stare?
Oct 10, 2008 | Intel Motherboard
Need to connecte wires to power sw, HHD Led etc. for pm8m mother board
You can download the manual from this site to connect the wires. If you need further help just respond to this post or thread
http://www.graficall.nl/pdffabrikant/4710F.pdf
Sep 02, 2008 | MSI PM8M-V Motherboard
Ihave a emachines modelT2792 and have een told the mother board is no good as well as the power supplycan i get another mother board for this computer or is it too old to fix it is about 2 years old
when all some other parts are good maybe you can replace the the mother board and the power supply.
you should find motherboard replacement that will fit to your processor and Memory.
if the memory , processor, hard drive are good, then you can contact your vendor if the have replacement(mother board) and power supply.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 15, 2008 | Computers & Internet
Intel Motherboard Logo
74 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
