The display is kinda blurred , and the text is not all that clear, which is straining the eyes...i checked for sharpness..no option available for that on the monitor..tried tweking a bit that didnt help as well...is there an issue with the display timining....please help me with this..its causing a lot of trouble..coz all my work is related to the computer and internet..thanks
Does it happen as soon as you switch on the computer ,before windows?
If so then it's a monitor problem with the focus , try doing a degauss on the monitor itself.(should be on somewhere on the menu)
To make sure that it is or isn't the monitor connect it to another computer if possible.
Please check 2 things.
1) Refresh rate of your monitor. Make it somewhere between 60-70 Hz. Otherwise this problem may occur.
2) Unplug the VGA cable and re-plug it.
If even that does not solve the problem. Then go to the device manager and then uninstall the graphics card and restart your computer.
Do let me know if you need detailed steps on how to go about it.
That is to check the refresh rate. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
Alternatively, right-click the desktop, and then click
Properties. Click the Settings tab, and then click Advanced.
Click the Monitor tab, and then click the screen refresh rate that you want to use.
Also perform one more step to judge where the problem lies.
While the monitor is ON, unplug the cable from the back of your computer tower. This should give some colored boxes on the monitor. See if they are blurred too.
thanks yah...taht was very quick, i am still confused with the steps..was on the menu on the monitor..it has display timinng..no refresh rates there...so it will be very helpful if u can give me the detailed steps...thanks..
i have already tried doing a degauss..that did not help,,,and with regards to the 2 soln ..can u please help me with the steps so i can do that and check wheter its workin..
