Question about Logitech X-530 Computer Speakers
No sound comes out of my speakers and the on light no longer works...but you can listen to music through headphones. can anyone help?
    Problem Solver:
  • 9 Answers
First check the power supply for the speakers/try in different power outlets/check the sound options in control panel
Posted on May 14, 2009
No sound coming out of speakers but lights moving on board
The Efx 12 has two outputs monitor out as well as mix out ( XLR sockets ). If the level bars are moving its an indication that the mixer is working. Have you tried headphones out as well as monitor out.
What is your amplifier and speaker setup- you have not mentioned it at all.
Even if any PFL switch is on you won't get sound out of the speakers.
PFL stands for Post Fade Listen and when any of the 12 channel PFL switch is on only the headphone out put will work.
May 18, 2011 | Soundcraft Efx12 - 12 Channel Sound Board...
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
I can't hear any sound on my verizon wireless razzle phone. It just stopped working after i plugged in headphones what is wrong with my phone?
I had this very same thing happen to me yesterday after listening to music with my headphones. After unplugging them, the speaker would no longer work nor the speakerphone.
After trying many things without success, I was finally able to resolve this by plugging back in the headphone cable and pushing the jack around a little bit to the side until I could hear sound.
I did this while trying to place an MP3 just to make it easier. So far this has worked fine. But now I am reluctant to use the headphones any more.
I know your post was several months ago so this may or may not be helpful.
Oct 27, 2009 | Cell Phones
Sound will not play through headphones
Try here:http://www.computing.net/answers/windows- xp/headphones-amp-speakers-switching/55486.html Also:http://www.vistaheads.com/forums/microsoft-public-windows-vista-music-pictures-video/133605-sound-doesnt-switch-automatically-headphones-when-plugged.html Also:http://www.vistax64.com/sound-audio/198039-sound-doesnt-switch-speakers-headphones.html scroll down the page for the discussion.
Oct 18, 2009 | Philips (33-01-031) Headphones
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
Speakers are disabled and can only listen through headphones
My daughter had the same problem. What has probably happened is that the chip that is inside the headphone outlet has become stuck and your macbook thinks the headphones are always plugged-in. There are several suggestions that we tried but decided to send her macbook back to Apple for a new chip. This is a KNOWN problem. For more detailed info and suggestions try http://www.macriot.com/article.php/20080718032528619. Good luck!
Mar 15, 2009 | Apple MacBook Pro Notebook
I cant take or make calls on my iphone without the headphones in.
Yea it sounds like the headphone have a sync problem. what you can do i go the Apple store and they should help you out they will swap your headphones and then it should work.
Thank you, Apple Care Technical Support
Jul 21, 2008 | Apple iPhone Smartphone
Odd Sound Problem...
sounds like headphone plug in is bad sorry no way to fix this unless you reinstall new head phone plug in .. lala linda
Jun 07, 2008 | Acer Aspire 3680 Laptop
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Logitech X-530 Computer Speakers Logo
228 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
