Question about HP 530 Notebook PC
Installed wrong version bios on HP 530
I installed the HP 550 Notebook bios onto my HP 530 bios, now when powered up, just the charging LED ( when charger plugged in ) Shows , as well as the power LED, but no sign of any activity.
Any help ?
  • 1 more comment
  • Anonymous May 15, 2009
    Hey Abhisek,
    So if i open the laptop and remove the cmos battery, its going to reset the bios or just rom ?
    See i was updating all my drivers from the HP site, but what i didnt realize is I have a HP 530, and was installing HP 550. Stupid mistake, and cant believe i didnt pick it up. Anyways im sure im not the only person whose installed the wrong version of a bios.
    Thanks, will try the battery and let you know .
    L0vej0y
  • salut89 May 15, 2009
    I have the same problem I installed a wrong bios for my hp 530 and the bios got locked. when ever I start the laptop it asks for the password ..I tried restarting the cmos by taking of the RTC battery but it didnt work .....can any one please help????
  • Anonymous May 24, 2009
    Any one ??
  • 115 Answers
U can try reseting the BIOS.onlyt option is taking out the CMOS battery and then putting it back but in tat case u hav to open up u r keyboard ,,its a bit risky,,so u better call up tech support for locationg the CMOS battery
Posted on May 14, 2009
How to remove bios password on hp 530
The easy way is to remove the CMOS battery from the motherboard. The CMOS battery is like a larger version of a watch battery. Once removed replace and bingo. Regards Gordon www.ourtechguy.co.uk
May 03, 2012 | HP 530 Notebook
No Power, Battery charge light stay on
Hi Roger
First of all Technically a battery of any laptops usually loses performance after 500 (Full charge-recharge) cycles of usage, However it will work by holding shorter charge duration compare the brand new one. If battery is not being recognized you might have have older version of BIOS as Compaq has released newer version of BIOS for NC 6220. You can download the BIOS update from official website of hp-compaq. BIOS update should be done very carefully. As installation will prompt you the instruction. for your convenience I am adding the direct link for the BIOS update that you can download and install.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=447371&prodNameId=447348&swEnvOID=1098&swLang=8&mode=2&taskId=135&swItem=ob-47873-1
Please follow up your post for further conclusion
Good Luck
Jan 04, 2008 | CMB T43 750 Notebook
When i putu the power cable on, the led light blink once and goes off. the screen is black. no fan is moving or any sound.
You should try to start your computer without the battery installed. If that doesn't work, you should try another power supply. If that doesn't either do the trick, it could be the motherboard causing the trouble.
Jun 14, 2011 | HP 530 Notebook PC
Forgot password for my hp 550 laptop with windows 7 professional
at start up press F2 to enter onto the BIOS settings and disable the administrator password.
Oct 06, 2010 | HP Business Notebook 550
Im using hp 530 and when trying to re install xp
you need to change native SATA settings in bios. then you can install windows xp. The steps are below
  1. Turn off the computer.
  2. Press the power button and press f10 to open the BIOS Setup.
  3. Use the cursor to navigate the Configuration options to locate the Native-SATA setting.
    • If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer
May 05, 2010 | HP 530 Notebook PC
I'm having a problem with my hp 530 laptop.....the fan is running too high...how can i fix this???
some times this happens with hp laptops and can be resolved by updating the bios. Go to the HP website and check the drivers for you model and see if there is a newer version of bios. Also run the diagnostics on it and it will test to see if it is a fan problem or mother board problem.
Jul 15, 2009 | HP 530 Notebook
On HP 530 notebook battery/power indicator is always on as long as battery is connected and even when ac power is connected the situation is still the same.
Clarification of your battery/power led indicator:
Solid amber:
Battery is charging at 0% - 89% capacity
Solid green:
Battery is charging at 90% - 99%
Blinking amber:
Battery is low
Led is of:
Battery is charged
Dec 04, 2008 | HP 530 Notebook PC
Drivers don't install on HP laptop
First we have to install UAA driver before installing the audio and modem drivers.
Here is the link for UAA driver:
ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing UAA driver restart the notebook and then install audio & modem driver.
Sep 11, 2008 | Computers & Internet
Bios update
Hello!!
I am not sure after installing which update the display has gone. I mean Windows update or HP software update or BIOS update.
Let me take the senario of the BIOS update and assist you in this regard.
If the display has gone after installing the BIOS update, then the issue cases are 1. Installed wrong BIOS update 2. Notebooks might have restarted or hanged while installing the BIOS update.
In both the cases BIOS will get currupt and there will be no display on the notebook.
Solution for the issue is: If you notebook is under warranty, HP will arrange for mail-in repair, plss contact HP. If the notebook is out of warranty, then you need to contact HP authorized service center.
Aug 07, 2008 | HP Compaq nx7300 Notebook
HP 530 Notebook PC Logo
937 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
