Question about Acer Aspire M1641-U1521A PC Desktop
MY cpu doesnt respond and doesnt start up.
I had a problem of my pc having lost some boot files. not having my own installer, i borrowed one. tried it on and accessed the cd. then it all got crapped up. after crashing. it went worse, now my cpu doesnt respond. The power is on but my monitor is empty, and suddenly turns to standby mode just as if the cpu is not powered at all. I hear no sound when i start up, and when i open it, it just stays blank. please help.
  • marloneroles May 14, 2009
    o and the monitor says NO signal
    Sergeant:
    Champion:
  • 225 Answers
Please try to reseat your memory module & VGA cards, then recheck your cable connections from VGA card port to monitor, also connection of your HDD from motherboard taking note of its jumper settings. regards
Posted on May 14, 2009
Toshiba l455 wont boot
no boot's, there's a few little tweaks people have been leaving on boot ups all are good to know but, put the repair disc in, f8 on most as it loads up f8 it, then start from cdrom, run the cd this will put you into recovery mode, hope this help's
Jul 30, 2012 | Computers & Internet
Replacing hdd with new hdd with noway to recover my os win7 64 bit
Do you have the OS install CD? Hope you do... if not you may be out of luck unless you can borrow a copy from someone. To use your original OEM code it would have to be the exact version OS originally installed on the PC. Dont toss that bad drive yet though. After reinstalling the OS, add the bad drive as a slave and unless you beat it to death... you should be able to access most of the files on the old drive. Good Luck.
Apr 20, 2012 | Computers & Internet
Computer powers up but wont display anything or respond to any buttons. HDD light flashes along with the CD drive. The problem started after holding down the power button for 5 seconds to do a emergency...
Weird though I dought that had anything to do with it. I would start by replacing the ram this will cause a no video boot as will a bad or overheated cpu. First b4 u spend money on the ram try hooking the external VGA output to another monitor see if u get boot screen. If not then start with the ram. If that doesnt fix it it may be a faulty motherboard which means time for a new laptop. Always get a shop to look at it b4 u trash though....
Aug 13, 2010 | HP Presario V5315WM (RG325UAR) PC Notebook
Turn on emachine, and dos menu pops up saying windows could not start because the following flile is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM then under that it says, you can attempt to repair this...
Borrow an installation Cd of your OS. Configur your computer to boot from CD.
Boot from CD, Choose (R) repair option. The recovery Console appears. Enter the number (1, 2 or other) that corresponds to the partition the system detected. If you see only one installation then you enter 1. You will then be asked to log in as administrator by supplying the password you entered whwn you installed.
When the C:\> prompt appears type
COPY [your_file_name] [SPACE BAR] C:\WINDOWS\system32\ [your_file_name]
After that Press [CTRL][ALT][DEL] to restart.
It should copy the missing file and you will be able to reboot.
Hope it helps
Rate the solution if it solves your problem.
Sep 01, 2009 | E-Machines eMachines Desktop PC
Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Jul 03, 2009 | Acer Computers & Internet
MY LAPTOP DOESNT START
try this http://support.microsoft.com/kb/314477
good luck.
Dec 26, 2008 | Gateway MX6440 Notebook
My pc get dammage
try replace RAM Modules Or Graphique card and tell me what u got
plz rate this post
Oct 10, 2008 | Intel Motherboard
Compaq presario # SR1810NX model
Please try to uninstall the memory and fixed back then start the computer.
i same problems; Back up your important files and then provide windowsxp bootable disk and boot to cd/DVD rom and install the new windows.
Jan 04, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Failure to operate hard disk
If I understand your posting correctly, the computer need not be repaired since all your after are the files stored in the old hard disk (HD).
If that is the case, you simply need an external drive enclosure to house the old HD (chances are IDE) with USB cable interface to be hooked up to another PC that is operational. From there you can then copy/move your files. This is of course assuming that the HD is still working/operational/recognized by the 2nd PC. Additionally, you can also run file recovery software(s).
You can borrow such an enclosure from a tech friend or purchase your own from any reputable computer shoppe/store.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 30, 2007 | Seagate HDD 40GB 7200RPM ATA100 2MB...
CPU problem
Here are possible solutions to your problem. Since you didn't give us some beeps from your PC.
1. Measure the voltage of CMOS-Battery it should be 3V if not change it, P4 is sensitive to it. OR
2. Try other memory first to test if it works fine. OR
3. You needed to refresh the installation of your windows XP to bring back or to repair the files in its system. Boot your WinXP CD and there find the one that refreshes the installation... Don't worry it will not erase your files... It should not try to create a new file-directory.
Nov 16, 2007 | Computers & Internet
Acer Aspire M1641-U1521A  PC Desktop Logo
173 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
