Question about Sharp Televison & Video
Sharp TV CX51N3 How to tune channels
I have been given this tv from my sister but shoe could not find the users manual for it.
Of the four tv channels that she had tuned in only two work and they are on different settings to the ones she had e.g on channel one she had tv1; - I only get a snowy reception on channel one; tv2 was tuned into channel two, but I can only get it on channel 7 (and when it first displays the screen shows a red dot then 7 with the word PAL underneath it.
How do I tune the channels and change the settings so tv1 displays on channel 1 etc channels?
Here's the link to the full user manual.
Cheers
Rich
http://support.sharp.net.au/downloads/opmanuals/CX51N3om.pdf
Posted on Jun 01, 2009
Sharp TV Model 32L-S400B - Reprogram Channels
Download the user manual to your Sharp TV by this link. It will ahve all details. OK?
May 21, 2012 | Sharp 32L-S400 32" TV
How do I tune the channels on a sharp cx34g3 TV. thanks
Yes, according to the manual, press PRESET, then VOLUME DOWN to automatically set all the channels the TV can pick up. Sharp has the manual for this model at http://support.sharp.net.au/CustomerCare/Operationmanuals/default.asp
Oct 01, 2010 | Televison & Video
I was given a Sharp 27N-S100 27" TV. Everything's fine but I don't have the remote control or user manual. I would like to get to the menu screen for the tv. How can I do this. Its hooked up to a cable box...
On the front of the TV you should be able to press both channel up and down at the same time and it will give you access to the TV menu. Once in the menu use the channel and volume up and down buttons to navigate.
Good luck....
Jan 13, 2010 | Sharp 27N-S100 27" TV
How do I tune in Sony Triniton tv please
Hello
The first thing is to try going in the tv's menu
It should be similar to this:
Menu>setup>channel setup
once you find something similar, run the channel setup and it should add in the channels
If that doesn't work, screw on the cable wire, unplug the tv for a good few minutes, then replug the tv and it should automatically scan
Hope this helps
-Chris
May 01, 2009 | Sony Televison & Video
Does the Sharp 32U-F810 TV have a digital tuner?
No it only supports analog. I'm pretty sure no CRT TV would be digital reception. Here is a link... Scroll down until you see the specs. First line is your answer: http://www.ciao.com/Sharp_32F540_CRT_TV_CRT__10021988#productdetail
Apr 27, 2009 | Sharp 32U-F810 32" TV
I cant tune in my tv its a sharp dv5103h abd i have lost the manual
Dear customer,
Sharp TVs often require you to press the TV Tuning preset key which is a yellow function key.
   Setting Up Your Sharp TV
Turn on your TV.
  1. On your Tune In remote, press TV and release.
  2. Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
  3. Enter the first three-digit TV code for your Sharp from the list which follows:
    093, 165, 039
    These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
  4. Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
  1. Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
  2. If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
U can also refer to the following link for ordering manuals  http://www.aerialsandtv.com/tvservicemanualsmainpage.html
Plz rate this solution..
Apr 09, 2009 | Sharp Televison & Video
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
Tuning My Tv
If you've store the earlier channel, off the tv and on it again. Every should come back as normal.
Regards
alan
Mar 02, 2008 | Televison & Video
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Tv, can't tune in channels
Sounds like he accidently put it in parental lock, the remote should have the "key", the user instruction book will have the answer also. Hope this helps
Aug 16, 2007 | Sharp 14U-FM1 14" TV
Televison & Video Logo
604 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
