Question about Tomtom GO GPS Receiver
Battery indicator on Tomtom One: on screen not always seen.
How can I check the on-screen condition of my battery whenever I choose to do so?
  • 4 Answers
Tap the lower right corner of the screen. A battery-shaped icon will be displayed showing state of charge.
Posted on May 30, 2009
Unable to turn it on ,only lighted screen and connection ca be seen
First of all, make sure the battery is fully charged. If you're not sure your car charger is working, try charging it with a USB-cable on your PC/Mac.
Once the battery is charged, RESET your TomTom.
Old TomTom's have a RESET button on the bottom. One model has it's reset button hidden under a cover.
Newer devices don't have a reset button. You reset them by "KEEP PRESSING THE POWER BUTTON A LONG TIME"
Try pressing even more then a minute. Eventually you should hear the TomTom "Drumm Roll" (the starup sound), and your GPS would start normally.
If this doesn't work, Try updating the device firmware using a USB-cable and the right software depending your device. Older devices use TomTom HOME, never ones use TomTom MyDrive.
I wish you a lot of succes!
May 14, 2015 | Tomtom GPS
My tomtom 3rd is frozen on screen and i have reset it, but stil not working
Hi, this is a common problem, there are some things to try.
First open the unit up and remove the battery and then reset, with little "button". replace the battery and then connect up to TomTom Home, and logon to TomTom website and see if you can update your software.
If you cannot, then the only course open now is to return it to Garmin, for a repair, they a re pretty inexpensive and you always get a result.
Tomtom support link below, use this to troubleshoot if you wish, also the contact link is there too.
http://www.tomtom.com/support/support.php?ID=2
Sep 26, 2010 | Tomtom ONE 3rd Edition GPS
Last week I updated my TomTom One with the latest maps, etc. Since then whenever I use my TomTom it keeps displaying a "Shutting down in 10 seconds" screen, with follow up screens, and then it shuts down....
Make sure you have "never turn off screen" checked, To do this tap "change prferences" tap the forward arrow until you see "battery saving preferences". Tap "battery saving preferences" then tap "never turn screen off". Tap "done" and make sure that "switch off when external power is lost" is not checked. Tap "done". If you do not see this option go back into "change preferences" tap the forward arrow until you see "show menu options" it should read "show fewer munu options"
Sep 26, 2009 | Tomtom One XL GPS Receiver
Tomtom keeps rebooting by itself soon after being switched on
Here is a solution that worked in my case (constant reboots after voice select)
  1. Plug your tomtom into your PC.
  2. Run TomTom Home
  3. Select the option to run your TomTom through your PC (TT Home)
  4. You should be greated with the select language screen
  5. Then simply select language etc.
  6. When you get to the voice selection: select a voice (here TTHome should freeze) <- also strangely enough notice the cancel button doesn't on the screen (as it does when doing this on the device)
  7. Don't panic TT Home should start working again in a few seconds
  8. Disconnect your TomTom and that should have solved the problem, the normal map screen should show up upon starting up your TomTom
This solved the issue for me, hope it does for you good luck!
Aug 22, 2008 | Tomtom ONE GPS Receiver
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
TomTom ONE XL will not power up or charge in my vehicle.
your fuse is burnt up to your cigarette lighter power supply try it in another car
Jul 12, 2008 | Tomtom One XL GPS Receiver
Always have to reset clock
Have you gone to the TomTom site to see if there are any new upgrades. There may have been a miss program in that model that may need to be upgraded.. I use a tomtom and have not had any trouble.
Jun 06, 2008 | Tomtom GO 910 GPS Receiver
Tom tom 3
This is a battery save setting.
Check settings under Battery Saving Preferences, choose Never Turn Off Screen
Apr 03, 2008 | Tomtom ONE GPS Receiver
Will not charge
I have a similar problem and I think I solved it (orr found a way to work around it). It looks like the contacts are not connecting firmly so even though the green light may be on, the charging conneciton is not made. With the tomtom on your home dock from the front page on your tomtom, touch near the lower right of the screen on the satellite strength indicator, this should bring up a screen where it shows (among other things) your batter status at the top right. If it is charging, the word charging will be under the battery strength indicator. Just play with it until you get the word "charging" to appear under the picture of the battery.then HANDS OFF until it is charged. I doubt this will be successful with the car charger since the movement of the car will likely jar the connection loose. Good luck.
Oct 03, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO GPS Receiver Logo
942 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
