Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Formatting on Canon IXUS75
Hi
I was playing around with my camera last night trying to get the photo delay shorter and stumbled across the "format" bit on the menu. Not knowing what is is and pressed the button. now all my pictures have gone? can you tell me what the format bit is? and if there is anyway of getting my pictures back?
Thanks
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Formatting erases all information on the memory card, preparing it for further use.
If you haven't done anything else to the card since formatting, you may be able to recover at least some of the photos. Do a Google search for "data recovery software" and select a program for your computer and operating system. Put the card into a card reader attached to your computer and run the program.
Posted on Aug 18, 2012
t00nz
  • 4738 Answers
SOURCE: Ixus 75
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 08, 2008
t00nz
  • 4738 Answers
SOURCE: i accidentally pressed the formatting button on my
The answer is it depends on whether or not you conducted a "low level" format or not. Such a format will actually write over the card making photo recovery unlikely. But with Canon cameras, format is normally a quick erase (which is recoverable), UNLESS you manually check the "low level format" box in the menu (did you do that?). But either way, there are numerous freeware software options available for photo recovery that may work for you.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
Posted on Jun 30, 2009
  • 11967 Answers
SOURCE: Any internal backup memory??
The internal memory only works when no card is in the camera and then only holds a small number of pics. If you had the memory card in the camera most of the time, most of your pics were on the card.
Posted on Jul 07, 2010
t00nz
  • 4738 Answers
SOURCE: hi there. i have a canon ixus 30 camera. i brought
Many people are unaware that the newer SDHC format cannot be used with most older cameras. Your camera was manufactured well before the SDHC format came out. I'm sorry, but there's no way that a 4GB SDHC card will work with your camera, it just doesn't understand the new format of the card. The max size card that you can use with your camera is a standard 2GB SD card. More info may be found at this link.
Posted on Nov 18, 2010
LongPockets
  • 1177 Answers
SOURCE: I cannot format the memory card using my Canon
You don't give any details about the card that is not working in your camera. I suspect it is not an SD card but an SDHC (high capacity) card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If this is the case, try a card of 1GB or less. This will hold plenty of pictures, 60 times as many as the 16MB card. If you really need more space then just carry a spare 1GB card and swap when you fill the first one.
Posted on Jan 04, 2011
All my photos from yesterday were deleted, and I have no idea how. No one touched it. I was fiddling with the settings last night. Could I have accidently set it to auto-delete or something?
I think you accidently selected FORMAT option from settings, Formatting the memory card erase all the data including protected images and other file types. So, once you formatted the memory card there is no way to restore them.
Thanks...!!
Nov 27, 2010 | Canon PowerShot A1100 IS Digital Camera
I have a memory card error appearing on my camera. My camera is ok just the memory card as i have tried using another card in my camera. It happened last night after taking photos when my battery was low....
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jul 30, 2010 | Canon IXUS 80 IS Digital Camera
Hi, I got a new ProSpec 4gb flash card and used it last night in my canon 40d. I forgot to format before I initially used it. Shot lots of great images that I could see on the camera back, but now I am...
I do not have a solution, but I do have same problem, or a variation of it: filled my ProSpec 2GB, removed it from my Canon G10 to insert a fresh card, then later reinserted the ProSpec to transfer photos to computer. Several tries, and no go. First time the camera display read "card locked"; I removed it and it was not locked, but I gently toggled the card switch back and forth anyway, then reinserted the card in camera, and the display read "card damaged". I then inserted the card into a card reader, actually several of them, and the computer did not recognize the card. So, I too am stuck.
ProSpec is a Calumet product, so I called a Calumet retailer (close to me in cambridge MA); the problem was new to them, and they asked me to bring the card by, so they could try opening it on their equipment, which I will do tomorrow, and I will let you know.
I do not think that I have ever had to format a card on a G10, and I would highly recommend that you not try formatting a card that has important photos. I believe that formatting always begins with erasing everything on anything.
Best, Jack Lueders-Booth jbooth@post.harvard.edu
PS - I cannot recall ever having experienced problems such as this with either Ilford HP5, or Kodak Tri X.
Jul 25, 2010 | Canon Cameras
Memory card full but wont show any images.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this AFTER you've recovered the photos.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a USB flash card reader with this software. If you don't have one, get one, they're inexpensive these days with cost not an issue (around $2 for an SDHC portable). Just make sure that the reader that you purchase states that it's capable of reading SDHC cards.
Jan 31, 2010 | Canon PowerShot SD870 IS Digital Camera
Long delay before can shoot another picture
This can happen when the card is nearly full or you've been deleting the pics but never formatting the card to give it a fresh start. Download any pics from the card and then format it in the camera.
Jan 23, 2010 | Canon PowerShot A550 Digital Camera
Canon rebel xti 400d
sounds like a problem with the card
what card are you using?
try formatting it. or try a different (maybe faster) card.
Oct 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Memory card error - E50
Try formatting the memory card via a card reader connected to your PC. Use FAT32.
May 24, 2008 | Canon PowerShot A75 Digital Camera
Ixus 75
Jan 07, 2008 | Canon IXUS V2 Digital Camera
Downloading photos to pc after connecting to a mac
Chances are you have some other program running on your system that's access your camera so that no other program can access it./ check all your start up items
Oct 13, 2007 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
53 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
