Question about Gateway (M520HD80G) Hard Drive
I have a gateway laptop model MA7and it wont start up.
When I press the start button it runs for about 5 seconds ,displays Boot Menu F10, Bios Settings F2 , a gateway logo ,an intel celeron inside logo ,along the bottom of the screen it says press F2 for system utilities and a progress bar fills appears but stops about 75% of the way then the screen blanks and hard drive stops
  • 3 more comments
  • fiveroomer May 14, 2009
    No , the progress barr is to the right of press F2 along the bottom of the screen
  • jav_2000_1 May 19, 2009
    Windows XP Media Center 2005 SP 3 Gateway MA7 laptop. Windows will not load, it gets stuck at a point with the windows XP logo and a progress bar below. I've tried safe mode and last good settings, but have had no luck. I have a recovery disk that came with the laptop. It is labelled "Recovery 1 of 1" I tried a recovery but it prompts for a disk 2 that I do not possess. When reentering disk 1, it says that it is not the correct disk.
  • Chris
    Chris May 11, 2010
    You may have a hard drive failure then, try restarting and hitting F2, it will allow you into the bios menu. Check to see if there is any Hard Drive(HDD) listed. If there is and it is stopping here the problem may be serious if there isn't you may be lucky enough to only have a failed/failing hard drive.
    Let me know what you find,
    Chris
  • Chris
    Chris May 11, 2010
    Is the progress bar on a screen with the windows logo?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 49 Answers
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
Posted on Jul 27, 2010
Gateway sx series sx2110g-uw318 boot menu
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
Jan 26, 2014 | Gateway SX2110G-UW318 Small Form Factor...
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
How do you refresh an older model gateway laptop
To restore Gateways you hold down the ALT and the F10 keys, then it should show a boot sequence screen, choose HDD boot and press down ALT and F10 again then you will get the restore feature for gateway. If that doesn't work boot into windows and run the eRecovery program.
Feb 13, 2013 | Gateway Computers & Internet
My gateway is stuck in configure 3 of 3 at start up
Turn on your computer. If your computer is already on, then reboot it. You need to see the initial display screen to get into the BIOS. Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information. The majority of Gateway computers use the F1 key. If, for some reason this does not work, then use the F2. All of Gateway's desktops use the F1 or F2 keys. this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Jan 22, 2013 | Gateway Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Computer won't boot up
To boot up
1)switch on the power button
2)when start press F2 until bios is not appear
3)go to boot menu and select your dvd or cd in first boot menu
4)press F10 for save and exit
5)it will restart before it you have to insert installation disc to dvd or cd drive
6)when appear "press any key to boot" then click ENTER button of your keyboard it will automatically boot.
thanks
Aug 14, 2011 | Toshiba Computers & Internet
I am Ravichandran, using HP Compaq nx6100 Model Laptop. My laptop did't boot and not even entering into Bios. Only HP Invent Embalam will appear and press F10 Rom Setup. If I press F10, F9, F1 there is...
If you are unable to "F-10" at power up, try 1}. unplug your laptop from AC adapter.
2}. press and hold power button until the computer powers up and powers off.
3} remove battery.
4). press and hold power button 10 seconds then release, replace battery.
5}. power up and press F10
If you are still unable to access BIOS you will need to obtain a system restore disk from HP
Apr 26, 2011 | HP Compaq nx6110 Notebook
Bought a Gateway model M465-E on Ebay only to find out the bios is pass-worded so I cant load Win XP because of The infamous "no hard drive error because of the Sata Driver,and i cant get to the...
I'm sorry but I don't know how to reset your BIOS. But to get around your problem, you should be able to enter the boot menu to boot to the optical drive to install your OS.
In order to access the boot options on this notebook computer, press the F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.
Dec 21, 2010 | Gateway M465-E Notebook
My hp womt start up the quixk start lighta cpme on then notging
If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
If there is a problem with the LCD display's back light or a corrupted graphics driver, the display may appear blank but the notebook may be displaying information. Attach an external monitor to test the display. If the image displays on the external monitor, there may be a graphics driver conflict. To resolve this, turn on the computer and press f8 key, then select Enable low-resolution video . If the image displays on the LCD display in low resolution, you can download and install the latest drivers for your specific graphics driver. If there is an image on the external monitor but the notebook display remains black, contact HP for technical assistance.
Even though users are instructed to disconnect all peripheral devices from the notebook when doing a hard reset, some devices are often overlooked.
Double-check that all devices are disconnected including: external keyboard and mouse (wired or wireless), USB connected external drives and devices, thumb drives and flash drives, network storage devices, PC card, SD memory cards, express card, eSata connections, firewire or similar devices, printer, scanner, camera, port replicator, or docking station, any CD/DVD from the optical disc drive, and any media from the multi-card reader.
If the computer can access part of the memory, it may be possible to access the BIOS Setup Utility display and perform a memory self test to identify other memory issues. If the computer cannot boot to the BIOS Utility, try removing and reseating the memory and the hard drive, and then repeat the following steps to perform the memory self test.
  1. Plug the AC adapter into the computer.
  2. Turn off the computer and wait 5 seconds.
  3. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
  4. In the BIOS Setup Utility, use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Diagnostics .
  5. Use the Up Arrow or Down Arrow keys to select Memory Test .
  6. Press Enter , and then Yes to perform memory test.
  7. After test completes, press f10 to Save and Exit , and then press Enter to Exit Saving Changes? .
Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. Use the steps below to test the hard drive in a computer using the HP Hard Drive Self Test.
Plug the AC Adapter into the computer.
Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup Menu.
Use the Left Arrow or Right Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer.
Turn off the computer and wait 5 seconds. Press the Power button to start the computer and repeatedly press the f10 key to enter the BIOS Setup menu.
Use the Right Arrow or Left Arrow keys to navigate through the menu selection to locate the Primary Hard Drive Self Test option. Depending on your BIOS, this may be located below either Diagnostics or Tools .
  • Select Primary Hard Drive Self Test , and then press the Enter key to start the test.
  • NOTE: The exact wording of the option for your particular BIOS may be slightly different.
    1. If Windows does not start properly, reset the BIOS to the default settings. Using the default settings, you should be able to boot into Safe Mode and install the latest BIOS. To reset the BIOS, press the power button to start the computer and repeatedly press the f10 to enter the BIOS setup, then press f9 key to Reset BIOS Default . For more information, refer to the HP Notebook PCs - Configuring the Boot Order in the System BIOS support document.
    2. If it will not boot to the BIOS, you may need to remove and re-seat the hard drive. Instructions may vary depending on the notebook model you are using. For specific instructions on re-seating the hard drive in the notebook, refer to the HP Notebook PCs - Steps for Removing and Replacing the Hard Drive support document.
    3. After re-seating the hard drive,perform a hard drive reset.
    Nov 16, 2010 | HP Pavilion dv6000z Notebook
    Gateway mx6453 wont boot up- oper system not found
    Restart the computer while tapping the deleate key this should bring you to bios go to advanced and check if the harddrive is listed with it highlighted press enter to enter the sub menu make shure its not disabled if it is enable it hit escape key to exit sub menu go to Boot on main menu set hard drive as 1st boot device set cd/dvd drive as 2nd boot device press f10 to save changes and exit. Try restarting
    if you get msg opperating system not found use the system restore disk
    Hope This Helps good luck
    Please leave feedback
    Nov 26, 2009 | Gateway MX6453 Notebook
    Gateway (M520HD80G) Hard Drive Logo
    550 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
