Question about Garmin nuvi 205W GPS Receiver
My Garmin Nuvi is frozen with a white screen, all I did was take out the memory card and it froze. What can I do?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Did you do this with the power on?
    - Jim
    SHARCNET-USA
  • 333 Answers
With the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Posted on Sep 15, 2009
  • yankeesfa592
    yankeesfa592 Jun 22, 2012
    Hold down the right button? There is no right button
  • 11 Answers
SOURCE: Garmin nuvi frozen
Did you press the reset button located under the antenna?
Posted on Aug 10, 2008
SOURCE: I have a Garmin Nuvi 200 and cannot load 2010 update
Install the SD Card. When you select your maps and transfer them to the device, make sure the Nuvi is plugged into the USB. When you are on the screen to "Find Device", select the dropdown menu and you should see the drive letter referencing your SD card. Select that and you should be all set.
Posted on Jul 22, 2009
SOURCE: My Garmin Nuvi 260 is frozen on the Garmin screen
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
  • 1111 Answers
SOURCE: my garmin nuvi 650 will not go to next screen it
have you tried the master reset?
plug it in to the usb port on your computer for a few hours.if that fails,then try the master reset.
note: that the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
if that fails, hook up the nuvi to the web updater and get the latest update.
download the updater HERE
(actually i would do this either way)
bill
Posted on Sep 27, 2009
SOURCE: The screen on my Garmin Street Pilot C340 is frozen
I read the manual. There is a reset button underneath the plastic cover surrounding the screen (pry off w/ your thumb) -- push the reset if the power can't be turned off otherwise.
Posted on Oct 02, 2009
Testimonial: "Perfect!"
Garmin nuvi 50lm only shows garmin screen and just a bit of green on the bottom. sometimes it shows the green register bar all the way accross
Garmin nuvi 50LM Boot problem ' POI Factory
www.poi-factory.com > Garmin talk
Aug 11, 2012 - Why won't my nuvi 30, 40, or 50 go past the Garmin logo screen when I turn it on? .... Just wanted to say thanks to Muell9K for the hard reset solution. ... get the Nuvi to start up with the screen that shows the picture of a Garmin ...
Crap... White Screen (nuvi 350)
May 11, 2008
garmin frozen?? (how do I reset?)
May 11, 2008
More results from www.poi-factory.com
How to Reset the Garmin nuvi 30, 40 and 50 with GPS City ...
? 0:51
https://www.youtube.com/watch?v=mujdSP-fM98
Jul 31, 2012 - Uploaded by GPSCity
In this video learn how to RESET the Garmin nuvi 30, 40, and 50GPS back to factory default settings. Back up all ... With the GPS unit off, press the bottom right hand corner of the screen. Turn the unit ... Show more. Show less.
Jan 05, 2016 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Frozen screen with Garmin
Try resetting it, otherwise leave it on for over a week until it's completely flat then try again
Feb 01, 2014 | Garmin nuvi 1390T Car GPS Receiver
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 froze up.
This is not caused by an update. Please check your unit's serial # to see if it starts with a "12P", "14V" or "143". If so, these units have a specific touchscreen that can fail even without physical damage to the glass or screen. The only way to resolve it is to replace the touchscreen & glass. You will not lose any of your data. The unit is not frozen and you can verify it by quickly pressing the on/off button. If you hear a beep, it's not locked up. You touchscreen has failed and won't accept any input. Please see this link:
- Jim
Apr 10, 2010 | Garmin Nuvi 660 GPS Receiver
Jul 17, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 200 frozen screen
Mar 16, 2009 | Sony NV-U71T GPS Receiver
Only half of sreen lights up and is frozen. Do all 350 have a memory card? When my husband brought it in from his last trip, there appears to be no memory card in it. Could this be my problem with only...
Stock Nuvi's from the factory do not include a memory card (SD card). You do not need a memory card to operate the Nuvi. The memory card is only needed if you want to add more storage space for music or pictures or if you want to add additional maps. It has nothing to do with the LCD display. Having worked on these units for quite sometime, anytime you have 1/2 of the screen missing, it tells me that your LCD display is defective.
- Jim
SHARCNET-USA
Dec 03, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 670 has frozen and will not switch off. I have held down the power switch for ages and this has no effect. Just got a locked screen of where it froze.
Jul 17, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 frozen
I did connect it to the computer via my USB cord - a Garmin menu came up and after opening a couple of the choices the Garmin was workable again. I don't really know why. But all is good here.
Feb 16, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
1,413 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
