Question about Sebo X4 Bagged Upright Vacuum
My upright sebox4 will not stand . It keeps on dropping down.
I have a Sebo upright and the clip on the bottom part is there but it cannot uphold the machine upright.
    President:
  • 389 Answers
This is usually a matter of lubrication (or lack thereof). If you look under the base of the machine, you will see that the "clip" as you call it is part of the metal axle on which the wheels are mounted. This axle is held in place by 3 metal tabs, each held by a single screw. About mid-way along, there's a spring coiled around the axle. That spring is what holds the "clip" (the bent part of the axle) against the tube that connects to the base of the bag compartment and holds it upright.
It's possible that your spring is broken, but often the problem is that the axle is sticking and the spring can't do its job properly. Try a small drop of oil under each of the 3 metal tabs. If that doesn't work, remove the 3 tabs completely, remove the axle (noting how the spring locates, so you can put it back correctly) and give everything a good clean. Then reassemble and try again.
Posted on May 15, 2009
My Sebo vacuum cleaner makes a whistling noise when standing upright
similar to the air relief on my dyson think it is so they don't burn motor up
Feb 17, 2015 | Sebo Automatic X4 Extra Upright Vacuum...
Tip
Useful Tips for Sebo's X1 Bagged upright vacuum.
Own a Sebo Automatic X1 Bagged upright or perhaps a Windsor-Sensor model? Here are a few tips to get more out of your machine.
When it comes to filter replacement, the standard cone/tube shaped filter can actually be cleaned by the Sebo if only just for a short moment just to get rid of any attached dirt the filter has accumulated. By removing the filter tube, the auto stop clip comes down, but by lifting your finger with this clip upwards and your other hand holding the bin door, the door can actually be locked back into position as it would normally. Then using the standard upholstery t shaped tool, clean the tube leaving it free of any dust and dirt contained in the tube. Once the tube has been cleaned you can take out the bin door and install the filter back in. Sadly the foam motor filter on the top hood cannot be cleaned or washed and has to be replaced.
If the filter tube however is completely stained and you dont have a free spare one to fit, the filter can actually be removed by removing the tie clips on the top and bottom of the holder. Wash the filter and dry in a tumble dryer - EBay in the UK sometimes sell filter squares which can be tied and locked to the cylindrical tube. Once the filter is dry you can then tie it up to the grid again and if the ties get lost, small computer wire ties are a suitable replacement.
Another feature of the Sebo X which has only just come to light recently with Sebo's user videos is use of the dry cleaning powder. Although Sebo don't actually tell you, by manually rubbing the powder into your carpet with just your fingers rather than raking it in on the top surface you'll get more out the first application of rubbing the powder in and letting it get a better chance of removing actual heavy stains. If you don't want to rub that powder in manually, remove the top hose by unlocking it where it meets the bag dirt channel on the left hand side of the machine at the top. (right hand obviously if you are facing the Sebo) then the Sebo X can be used as a rolling  brush to rub the powder in. After the 30 minutes minimum waiting time, lock the hose back into the X and vacuum up as normal.
This facility of removing the hose/thus cutting the suction is also very useful to rub in bicarbonate of soda into your carpets if you own pets. Bicarbonate of soda is an ideal natural odourizer which will maintain clean areas. Sebo's DuoP dry powder is ideal to do this as well for general stain protection if you like to keep your carpets clean.
The paper bags can also last a lot longer if the dirt your Sebo has collected remains half way at the top rather than naturally falling to the bottom of the bag.My X1 does this with new carpet fluff. Take the crevice tool and push the tool into the top opening of the bag to push the dirt GENTLY down - this will give you extra longevity on the bag used as well as not having to replace it so often.
There are ways to make your Sebo X1 cost effective!
on Mar 28, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo upright foot peddle came off how do I attach it back
yes but you will need a new spring to put on it or you can leave it off it will not harm anything it just will stop the vacuum from standing on its own so yes
Mar 18, 2014 | Sebo X4 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo squealing
Just spend all afternoon working this one out. Take the upright section away from the bottom by pressing the release button at the bottom of the upright section. You will see two pipes. One pipe has a grill on the top. That is the problem. Mine was slightly loose which may have caused the whistling or it may not have been making a good seal with the upright section. Anyway, I took it off altogether and the noise has gone
Feb 22, 2013 | Sebo X5 Extra Bagged Upright Vacuum
How do you cheng the filter
The Sebo X1 has 2 filters. Both should be changed once for every 20 bag changes. The long cylindrical filter in the bag compartment just slides out to the front - grab the little handle at the bottom and pull forwards - it can be a bit stuck, so you may need to lever it out with a screwdriver or similar. When you put the new one in, make sure you push the little metal lever back up behind it (this is just a simple device to prevent you from shutting the bag compartment when there's no filter present).
To find the second filter, release the foot pedal and lie the handle flat on the floor. This exposes a square panel with lots of small holes in it. Release that panel by squeezing the clip, lift it off and pull the foam filter out. Just drop the new one in and replace the cover, pushing it until it clicks into place. Job done!
Mar 27, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo felix upright
Hey Debs
Ive got a Sebo Felix. Unfold the bag (if its folded) and drop it into the top of the bin. Once you've aligned the plastic parts the two nibs which are pointing outwards towards the handle, make sure the plastic collar is sitting on the rest of the surround.
Now the most important aspect is the plastic flap - not the dust cap - but if standing behind the Felix, there is a green flap on the left hand side of the bag which must be pushed down over the spring (looks like a large staple). Once that is folded over and locked in, the lid should close. If the lid still doesn't close check that the top hose fitting has been securely locked and is dust free. Dont forget to rate, ty.
Jul 25, 2008 | Sebo Vacuums
Sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Jun 22, 2008 | Sebo X4 Bagged Upright Vacuum
SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
Feb 15, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo X4 Bagged Upright Vacuum Logo
165 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
