Question about Insignia LCDTV26 26 in. Television
Monitor says mode not supported
Installed mystery solitaire and when i launch it the monitor says mode not supported. i have an insignia lcd tv. any solutions would be greatly appreciated.
  • Insignia Master
  • 3,866 Answers
Yes the resolution your trying to display on your TV is not supported by your TV so you computer is warning you before doing damage to your TV. there are certain modes you can use and calling the manufacture or reading the manul will tell you what modes you can place this monitor in and then change it in the display menu of you operating system. the monitor is not the problem its the mode you in is not supported by your monitor so to not risk it your computer is telling oyu that is not supported so please look at the manual and go with the support it tells you.
Posted on May 14, 2009
I have a 55 Insignia tv it turned it self off and want come back on.i check the power and it want work either.
Won't not want.
Hi James,
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a
component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 13, 2015 | Insignia Televison & Video
My Insignia LCD 42" only
It sounds like it has main board problem, leave it unplug for about an hour to let it reset itself to see if it will work again. It can also be unstable power supply problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Insignia 42" LCD Flat-Panel HDTV
Just got an Insignia NS22E450A11, 1080p LED TV. Using as computer monitor primarily. Every time computer is restarted the screen will not display properly (racing lines & dots only). Computer is older...
The computer does not know the resolution capablilty of your TV, so it set to default resolution. You need to fond out if Insignia website has the driver for your TV. Are you running XP or WINDOWS 7?
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Please post back what you find.
Please leave rating if it helps.
Jan 31, 2011 | Insignia NS-LCD19 19 in. LCD TV
Insignia tv flashin led no power
It may be in startup/shutdown mode due to failure in the power supply, inverter board, main board. Need more in-depth troubleshooting first.
Learn more here:
Please see my basic troubleshooting guide here:
Dec 02, 2010 | Insignia NS-L322Q-10A LCD TV
Hello there! Our Insignia Tv was working and suddenly the screen went white. We've unplugged it, checked all the wires but we are not sure what the problem is.
White glow onthe screen and no image? If that is the case, then it can be the T-CON board or the main board problem.
Please read my guide to understand how LCD TV works.
Basic LCD monitor and LCD TV troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 14, 2010 | Insignia I-LC26Q1 Television
New hp computer not communicating with Insignia LCD TV monitor
before starting keep press f8. then choose safe mode then if you are in ur desktop try to ressetting your display 800x600 then finally done......
Feb 13, 2010 | Computers & Internet
I plugged in the VGA cord from my computer to my television
Most likely your current resolution isn't supported by the TV. Before you plug your TV up to your computer, set your desktop resolution to 1024 x 768. This is the standard and is supported by most if not all flat screens. If it doesn't work on this setting try 800 x 600 or 1280 x 768. One of those three should show up. If no resolutions work, then there is something wrong with the TV. If other monitors work on your computer then the computer is just fine.
Nov 06, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
VG4 mode on Insignia 19" widescreen LCD wont accept computer
go to your control panel of your computer (using a different monitor obviously) and change your screen resolution to 640x480, 800x600, 1024x768, or 1440x900. any of those resolutions should work. also go to advanced and make sure it is set at 60 herz.
Feb 25, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
INSIGNIA 26" FLAT SCREEN MODEL #246ALC27FB26006527
These LCDs have a feature to turn OFF after some time if they do not sense any signal getting into the TV, that is why when you use it as a PC monitor and leave ON; it will turn OFF by itself.
The short term solution to make the LCD power up properly when using it as a PC monitor would be to unplug it when it turns OFF by itself and plug it back in.
Let me know if you need further assistance.
Oct 24, 2008 | Insignia LCDTV26 26 in. Television
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
Insignia LCDTV26 26 in. Television Logo
1,047 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
