Question about JVC HR-S9800 S-VHS VCR
JVC S-VHS VCR 2002 model
Worked well until a few days ago. Display comes on briefly if switched on, and tape will thread around the head. However, the tape is then back threaded into the cassete and the cassete ejected. the display then turns off. Tried replacing timer lithium battery and checking no timer function is on. No success...
  • JeremyCliff May 16, 2009
    Do you mean that the power switches off and the tape unthreads because the heads are dirty? when you say blow it out, do you mean it could be dust that is causing the problem? Many thanks... !
    Genius:
  • 1,148 Answers
TRY A HEAD CLEANER,,AND BLOW IT OUT
Posted on May 15, 2009
3 Suggested Answers
SOURCE:
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 579 Answers
SOURCE: Videocassette stuck in Panasonic NV-G50 VHS VCR; can't eject
Generally, you have to take off the cover, and find the motor that drives the cassette loading mechanism, then turn the motor shaft with your fingers (many many times) until the cassette is unloaded.
Usually the moter is easy to get at on top just to the right of the cassette mechanism. However sometimes it is underneath and you can only get at it by taking everything apart. Don't try this yourself and don't take the cassette carraige assembly apart trying to get at the cassette unless you don't plan on using this VCR again.
Posted on Dec 29, 2007
Display blinking, but unit will not turn on.
It look like its a Philips turbo drive the power supply itself can having 1 or 2 bad capacitor(s) a broken intake is the most common part in this drives but it look like powersupply or a dirty mode select switch, but beware on marketing technical differences between the models for ordering parts this is not the rca manual and only to compare to this philips turbo chassis but the most critical parts can be equivalent if click the link on the screen down the picture search for the word processing be patient it should change to Get Manual Elektrotanya for electronics experts
Jul 27, 2017 | RCA VR646HF VHS VCR
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
thanks
Aug 04, 2008 | Televison & Video
I bought a JVC GR-SXM250u Super VHS camcorder a couple days ago and the picture has horizontal lines flashing in and out so I can't see in the display both in pause mode and in record mode. He said he...
you may have a faulty camera there,,,or the vcr tape may be faulty and has spred some of the tape on the recording head try running a cleaning tape through the vcr first to clean the heads,,then use a new tape (not the old tape!) to try that out,, if its cleans the head up throw away the old tape so you never put it back in this vcr
Sep 04, 2010 | JVC GRD250 MiniDV Digital Camcorder
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
Re: Model PV-4523S
You can try cleaning it with a VCR tape cleaner to see if the pinch roller have build up on there. It could be that the motor isnt feeding the tape up against the recording heads properly and may need an adjustment. If you can take the top cover off, you should be to see what the problem is by the way the tape is being inserted into the machine.
Jul 29, 2008 | Panasonic PV-V4021 S-VHS VCR
Tape won't load
The childlock feature might be active try holding the power button on the remote till the vcr turns on. when the VCR turns on try putting a tape in and see what happens I happen to own this very model and has been in service since july 98 and has over 10k hours on it and still works like the day i bought it
I had that same issue a few years ago
Jul 09, 2008 | JVC HR-S3500 S-VHS VCR
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | JVC HR-S3901 S-VHS VCR
JVC HR-S9800 S-VHS VCR Logo
102 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
