Question about Marantz SR-5200 Receiver
Loss of volume on left channel
Marantz SR-5200 has been trouble free for many years. However, recently started hearing the odd pop/hiss from left channel and now the left hardly gives any volume at all. If you put your ear to it you can just hear a signal. This is the same for Analog digital or tuner. Wondering if this is a known fault and if so is there a particular part that needs replacing.
Cheers,
  • 1 more comment
  • AggieLuke Jan 07, 2008
    I have also lost signal in my front left channel. There was no popping/hissing preceding it. One day it just stopped working at powerup. Have not tried any troubleshooting yet...
  • mark2003 Apr 02, 2008
    Likewise the front left channel just stopped working - I'm hoping that this does not require replacing the amp
  • GlennPDX Jan 06, 2009
    My loss of sound is in the right rather than left channel. Replaced with another receiver, and speakers are working just fine. Right channel now seems dead. Any way to convert inputs into a mono mode so it can deliver all material in a non-stereo location?
    New Friend:
    Problem Solver:
  • 5 Answers
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Posted on Jun 18, 2013
  • 682 Answers
Please repeat speaker setting from your manual and confirm that left channel is ok.-invert left channel plug with right channel plug if the problem moves from left to right you will have the problem in your speaker or its cable-if not the problem in your receiver itself.
you can apply contact cleaner in volume control and move it forward and backward and test.
Posted on Jul 06, 2008
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
Jun 03, 2010 | Marantz SR-5200 Receiver
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Mar 19, 2010 | Marantz SR-5200 Receiver
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Feb 11, 2009 | Marantz SR-5200 Receiver
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
SR-5200 owners manual
http://www.retrevo.com/s/Marantz-SR5200-Receivers-review-manual/id/511dj791/t/1-2/
Jun 26, 2008 | Marantz SR-5200 Receiver
Statics and hissing...
I also have the same fault, The static noise is coming out
of ic720 [ cs4391 or cs4392 ]on digi pcb which is D-A converter
this ic maybe faulty, i have ordered a replacement ic and will
post here if solves problem
Dec 10, 2007 | Marantz SR-5200 Receiver
Total loss of sound...what to do?
please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Sep 23, 2007 | Marantz SR-5200 Receiver
No output from left channel after crackling sound
Jul 08, 2007 | Marantz SR-4200 Receiver
Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Aug 26, 2006 | Marantz SR-5200 Receiver
Marantz SR-5200 Receiver Logo
643 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
