Question about Magnum DeltaForce CB Radio
My magnum delta force blows the higest amp fuse!!! (shorting out)
My magnum delta force blows the higest amp fuse i put in line. even when the it is switched off. any suguestions???
  • 181 Answers
Yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
Posted on May 15, 2009
Is there a diagram showing how to calibrate a magnum deltas force cb radio
I found it and so can you.Do a serch for magnum delta force radio. or go to www.bastardfairies.com
May 25, 2014 | Magnum DeltaForce CB Radio
No variable powere or am modulation
the "am" regulator is shorted. 2sa743 2sa1012or equivilent. less than $5 part..
Feb 04, 2014 | Magnum DeltaForce CB Radio
I cant call or receive with my magnum delta force cb radio in the am settings please help
What antenna are you using? What is the SWR on the antenna? Note that the swr wont necessarily affect Transmit but it will show if there is a general antenna problem like a short, that could be causing this. Otherwise it is an issue that needs to be diagnosed in depth on a test bench.
Sep 14, 2013 | Magnum DeltaForce CB Radio
My magnum delta force stop going on 27 mhz
You might have accidentally put it in to ham Mode i think Turn Off radio Hold function And Mode Buttons If I remeber Right
Nov 22, 2012 | Magnum DeltaForce CB Radio
Magnum delta force radio . while connecting my power wires in my truck i touched the the two of them together .radio went dead.what could be the problem .can i fix it myself.
You can say you hooked it up backwards,it blew the diode inside,this would be hard for you to fix without the right equipment.Please don't change the fuse in line and keep tring it because the more times you do the more chance you're giving it to take out more components.Take it to a shop and tell them what you did,It can be fix so don't let them tell you other wise.I own my own shop.
Jun 27, 2011 | Magnum DeltaForce CB Radio
Bad transistor magnum delta force q5 part number c102
i have a royce1-621 is there a way to put a 75 w amp in it ???
thanks bobbyrocket@hotmail.com 708-599-1223
Nov 19, 2010 | Magnum DeltaForce CB Radio
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Magnum Delta Force Radio: The schematic does not match what is on my work bench! Schematic shows 10 tact switches,there are eight on the unit. If I trace back the leads from the rotary frequency changer...
usualy that is a sign that someone was trying to get more channels then it already has which is imposible to get any mor ok check this web site cbtricks.com go to the radio information section go to m look for the magnum radio section look for the deta force you should find all you need there. good luck with your projec and god bless you.
james morgan
morgans electronics
Feb 28, 2009 | Magnum DeltaForce CB Radio
Magnum delta force
pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Dec 21, 2008 | Radio Communications
Radio Communications Logo
231 people viewed this question
Top Magnum Radio Communications Experts
John Porter
Jim Goldsmith
Jim Goldsmith
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
