Question about Samsung Televison & Video
Samsung Tantus 122cm rear projection tv - 2003 model - Australia - (fines lines)
My tv has recently developed fine diagonal sqiggly lines across the whole screen. This is visible from closer range. When I turn my pay tv box off, the blue screen on the tv still has the same problem. Do you have any suggestions as to why this is happening, and how it can be fixed.
Thank you.
SOURCE:
  • 1030 Answers
SOURCE: Mitsu 65 inch rear projection tv
yes sounds like a convegence issue.
Posted on Jan 03, 2008
  • 5 Answers
SOURCE: toshiba 42PW33Q rear projection gone blue
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Posted on Apr 15, 2008
Slinteriors
  • 8617 Answers
SOURCE: 53 inch panasonic projection tv.
check the yoke plug solder joint, as the squiggly lines in the middle usually happens if the yoke is unplugged. So check the yoke plug connections.
Posted on Jul 06, 2008
welcomejee
  • 10594 Answers
SOURCE: Very fine blue lines veiwable when the background has black in it
You need to adjust (actually bit decrease) G2 volts (calls Screen volts) of Blue gun.
If you are familiar with big TV repair and have electronics knowledge then let me know to guide you further.
thank you.
Posted on Dec 13, 2008
SOURCE: Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Posted on Jan 19, 2009
HI, MY REAR PROJECTION SAMSUNG TV SP53J5HF MODEL BOUGHT IN 2004 APROXIMATELY HAS RECENTLY DEVELOPED BLUE LINES ACROSS THE SCREEN. DOES THIS MEAN THE PICTURE TUBE HAS A FAULT AND IF SO CAN I BUY A...
You'll need to do a "Convergence" procedure on your television, which re-trains the
three color guns to focus on a single point, correcting the double-image problem.
This link points to a how-to video & also how-to instructions:
http://www.fixya.com/support/t7212007-colors_separated_double_vision
The procedure is actually in the instruction manual for your TV, and at least one mfr recommends that
this procedure be performed on the TV once each month.
Cost to you: $zero
Mar 28, 2011 | Televison & Video
Samsung DLP TV bad picture
Some Samsungs have a problem if the set is turned on bfore the input put device due to a firmware issue. Try turning on the device (game, DVD, etc) BEFORE turning on the TV.
Let me know if this helped.
visit my site:
www.mcveyelctronics.com
May 02, 2009 | Samsung HCM5525W 55" Rear Projection...
Diagonal lines on a Samsung 46" TV
picture is ok /converg.-ok/;diagonal lines on screen; looks like waves.Appear on tv and video modes.I observed same problem on some another tv in my practic,but this case is worse.
Sep 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Tv comes on and flick off in one minute
need to know the make and model number of the TV in order to help you.
Mar 13, 2008 | Televison & Video
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Lines on the screen
i have a samsung rear projection , and it has red lines going across the screen. i put it in the back of my cuboard and went out to buty a new tv . now a few months on i got it back out to have a play with it and i coverd up the red bulb with something fireproof and now the picture is great again just that there is no red anything that is red looks a bit darker. its not great but a least its some use now and i use it in my bedroom. it mite not be much help but a least i dont have to keep it in a cuboard anymore.
Mar 15, 2007 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
