Question about Photography
Cannon AE-1 , shutter jammed
I did not use my camera for a long time i think a few months so it got jammed how do i counter this problem but when it used to work it gave me great pictures please help me!!!!! urgent!!!!
  • 10,319 Answers
The magnetic shutter motor is worn out more than likely. A tech is needed to preform any repairs I would say
Posted on May 23, 2009
Canon AE-1 program shutter fires when cocked
Unless you are a camera technician, this is a problem that has to go in for repair. The mechanical hold is defective or broken. Please weigh the cost of repair vs buying a used camera
You can buy a used/refurbished AE-1 Program in the $80-$140 range. Call several repair places by looking on the internet, some will give a free repair estimate.
Jan 22, 2014 | Canon EOS-AE-1 35mm SLR Camera
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
I have a Canon AE-1 camera that I bought off of E-bay months ago. I just recently took the used film to get developed & when I picked it up the film only developed a few pictures, but the rest were...
If the camera is actually at fault here (and yes i always blame mine ;-]) it is usually due to the shutter getting out of time with the flip mirror. When you take a picture the mirror flips up out of the way and then the shutter opens and the camera actually takes the picture. What can happen i the track gets gummed up. Can be from old lube or the wrong stuff being used or dust. So when you take the picture the mirror doesn;t get out of the way and you get a picture of the back side of the mirror. I think that has a titanium shutter but older ones had a cloth shutter and those would stick a lot easier.
You can clean the track using isopropyl alcohol and cotton swabs. You need to be careful not to lave any cotton fibres in the tracks or the mirror or the shutter. Take the lens off and then push the mirror out of the way with a swab (don't touch anything in there with fingers) Wet a swab end and just follow the track a few times. It may take a few passes before any buildups start to loosen up. And you may not see much if any thing.
Don't use any lube unless you have a high quality silicon. So don't be tempted to spray some WD40 in there (yes I've seen some do that and then wonder why it doesn;t work). There is a reccomended lube but I'd have to dig out the shop manual for the series to find what it was. It either was a silicone lube or a graphite. Anyway if the cleaning improves or fixes the problem then you should be good to snap away.
Aug 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Loading film
After further investigation and because I can't keep my hands out of things I now know that the camera body is defective and that the shutter is jammed. It will only release with assistance. I was loading it correctly.
Apr 17, 2008 | Photography
Rewind on my camera wont turn
Has the rewind knob become unscrewed or just won't turn? It does have to be turned clock-wise to rewind the film. If you would happen to turn it counter-clockwise, it would either jam or the knob itself would become undone from the rewind shaft.
Dec 25, 2007 | Photography
Shutter stuck on Canon AE 1
Just now saw your problem.....I can repair this for you. No it's not "overwound" you possible have some small piece of plastic that caused your second curtain to get hung up and thus jam the entire camera. I have probably repaired 500 AE-1's with the same problem. Art www.flcamerarepair.com
Nov 22, 2007 | Canon EOS-AE-1 35mm SLR Camera
AE-1 won't cock ,shutter doesn't work
Take the bottom cover off and find the release magnet on the rewind end. There's an "L" shaped bracket that has a straight spring against it on one end and a magnet armature on the other ( under a plastic cover. Move the spring loaded end toward the front of the camera to release the magnet - the shutter should trip. If it does, install the battery and try it. If it doesn't, it has a mechanical jam and will have to go in for repair.
Sep 19, 2006 | Canon EOS-AE-1 35mm SLR Camera
Photography Logo
128 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
