Question about Garden
I have inherited a tacumseh vantage 55 lawn mower but no manual. What size spark plug and what gap also what type of oil is required ? Where can I obtain a owners manual.
  • 246 Answers
Hello keithanthony:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
>>The Spark Plug for Most Tecumseh Engines is a RJ 8C and it is Gapped to .030in.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
What fuel do I put into a Vantage 3.5 Tecumseh lawn mower?
If it has a place to add oil to the crank case, either a dip stick, or a filler opening at the bottom of the engine, then you just use regular gas. Be sure to verify that there is oil in the crank case before running it this way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jun 16, 2016 | Tecumseh Garden
Tip
Lawn-Mower won't start
Hi, when your Lawn mower is not starting, follow the steps and instruction below to troubleshoot and fix it.. <br /> <br /> <b>Engine seized</b> If you are unable to pull the start cord or if the electric starter will not cause the engine to turn over you may have a seized engine. Check the oil level, if there is no oil in the crankcase the piston may have become fused to the cylinder wall. Spraying a penetrant or lubricant into the cylinder through the spark plug hole can sometimes loosen the piston otherwise it is likely the engine will need extensive repair work. <br /> <br /> <b>Battery dead</b> Check the battery to make sure it is completely charged. Also check the cables to make sure they are tight and the battery posts are clean. <br /> <br /> <b>Spark plug fouled or defective</b> The spark plug may be loose and need tightening, the spark plug wire may be damaged or disconnected, or the spark plug may be clogged with oil, gas, and combustion residue. If it is clogged it can be cleaned with a wire brush. You may also need to reset the spark plug gap. The spark plug gap can be checked and adjusted with a spark plug gauge to measure the gap between the center electrode and ground electrode on the end of the spark plug. Check the required specifications in the owner's manual. If it's badly damaged, replace it. <br /> <br /> <b>Recoil broken</b> If you pull the recoil starter assembly and it pulls too freely or doesn't retract after pulling it there may be a broken or jammed spring, pulley, or cord. If the cord retracts but pulling the rope doesn't crank the engine, you will need to remove the recoil starter assembly to determine the cause of the problem. <br /> <br /> <b>Air-fuel mixture</b> Small engines need the proper amount of air and fuel (14:1) in order to start or run properly. An air-fuel mixture that is too lean (too much air) burns hotter and may cause rough idle, hard starting and stalling and a lot of misfiring. Check the choke to make sure it is not stuck in the open position otherwise the carburetor may need to be cleaned or adjusted. An air-fuel mixture that is too rich (too much fuel) is usually due to a dirty or clogged air filter or the choke being stuck in the closed position. The choke should be in the closed position when starting a lawn mower, however if the choke remains closed the engine will not start because the fuel and air mixture is too rich. <br /> <br /> <b>Oil into carburetor and/or combustion chamber</b> Oil can leak into the carburetor if the lawn mower has been tipped on its side (carburetor is not up in the air). If this happens the carburetor must be completely cleaned out using a brush or rag and a spray or liquid carburetor cleaner. <br /> <br /> <b>Starter switch or motor</b> If there is only a click sound when trying to start a lawn mower with an electric starter there may be a problem in the electrical system. Use a multimeter to test the starter switch, alternator and any other electrical component. Check the owner's manual for meter settings, speed, and readings.
on Dec 07, 2010 | Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Spark Plug Gap for a Sears Mower
Generally .028-.030" if its a small Briggs and Stratton engine.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 09, 2014 | Craftsman 55 Torque 158cc 22" Push Lawn...
What type of spark plug and the gap size
The Tecumseh Push mowers, most or all of the Tecumseh brands uses a Champion J8c, and the gap at .020.
Jun 24, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn motor backfire when starts?
Change the laminator. Part the spark plug wire is connected to. Air gap should be .025.
Jun 05, 2014 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Bosch spark plug gap
The type, size and gap of the plug will come from the owners manual of the engine. R on a plug means there is a resistor, i am assuming the 0 means that its saying there is no resistor. There may be more identification etched into the metal part of the plug just below the socket hex to find what plug you really do have.
Mar 09, 2014 | Briggs & Stratton Garden
Burns out spark plugs during every mow(victa vantage 2 stroke)
you are using too much oil in the gas oil mix, cut back to 50:1 ratio
Jun 25, 2010 | Garden
Garden Logo
561 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
