Improving print quality
The print impression appears lighter on one side (right side) of the page than the other (left side). I would like your help on how to have uniform print impression.
Thank you.
Girish Desai
  • 239 Answers
On this type of problem, take the toner canister and "Carefully" give it a gentle shake. The idea is to distribute the ink level equally on both ends of the modual.
Sometimes, the drum unit is part of the toner-developer modual. Do this same process see if it works.
Other problems could be dirty mirrors. Excessive dirt on the mirrors can cause faint copies especially if it is very dirty on one side of the mirror.
Another over looked problem is cigarett smoke. This leaves a blue thick haze on the mirros and lens which can cause these problems.
If the machine is located in a home, cooking smoke can leave a haze on the mirrors causing copy quality problems.
There can be at least 3 mirrors or more in the machine. On some lasers there can be some very small ones in the image head. These are very difficult to take out clean, and to reinstall. They have small locking tabs on the sides to snap them back into place. If they are broken, they may not install correctly and not funtion at all.
Good luck.
If all else fails Place a service call.
Posted on Oct 26, 2009
  • 24 Answers
Pls specify make and model
Posted on Oct 15, 2007
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Printer window displays in foreign language. need english. pages come out blank.
  1. From the main menu, use the left and right Arrow buttons to scroll to Setup.
  2. Press the Select button .
  3. Press the right Arrow button until the heading you want appears on the display, and then press the Select button .
  4. Use the left and right Arrow buttons to scroll through the available menu items.
  5. When the setting (language) you want appears on the display, press the Select button to save the setting or enter the submenu.
  6. For Blank printout:Ensure you installed the ink cartridges correctly and removed the sticker and tape from each cartridge.
Clean the cartridges:
To clean the ink cartridges from the operator panel:
  1. Load plain paper. .
  2. From the main menu, use the left and right Arrow buttons to scroll to Maintenance.
  3. Press the Select button .
  4. Use the left and right Arrow buttons to scroll to Clean Cartridges.
  5. Press the Select button .
The cleaning page prints. You may discard the cleaning page when printing is complete.
To clean the ink cartridge nozzles:
  2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
Click Printing Preferences.
The Printing Preferences dialog box opens.
  1. Click the Maintenance tab.
  2. Click Clean Print Cartridges.
  1. If the print quality has not improved, click Clean Again.
  2. Print your document again to verify the improved print quality.
If you are still not satisfied with the print quality, wipe the ink cartridge nozzles, and then print your document again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 20, 2011 | Dell 946 All-In-One InkJet Printer
Sir ihave printing problem when i print a page on the left side margin impression faded there is some faded portion of teflon roller crieate this problem please assist me how to solve this problem ...
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Aug 09, 2010 | HP LaserJet 1020 Printer
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
99% of printed page has light grey water mark-as if water-washed
Are you saying it is this problem?
Gray Background Print Quality Defect
Here's another error that might fit the bill:
Vertical Lines Print Quality Defect
If these documents don't quite describe the issue, please post back with more details. Thanks.
Oct 14, 2008 | HP LaserJet 1020 Printer
Printing lighter on left side
Try cleaning the corona wire/ charge roller if this doesn't work replace the image drum
May 16, 2008 | Samsung CLP 300 Laser Printer
Poor quality impression
I am supprised your repairman couldnt fix this, either the hammer is binding or the V 1 resistor on the logic board needs adjusted I do this repair in my shop quite often.
Jan 18, 2008 | Swintec 7040 Typewriter
272 people viewed this question
k24674
jasbo
jasbo
