Question about Dell InspironTM 1501 Notebook
DVD R/RW Wont dont anything
My cd rom will not do anything it wont open play cd when i open it with a paper clip in the pin hole I had to Redo my computer and since then the cd rom does'nt work. When I go to my computer it says DVD RW drive(E:) I went to properties and it says it is working fine and then i did a update and it said my driver was up to date. there is'nt a cd in the drive. can you please help me.....?
  • 114 Answers
From the device manager, Right click on the drive and uninstall it. Then restart your computer. See if that helps.
If still not, then you can try this step.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Posted on May 14, 2009
Cd rom wont open
Hi in front of the CD-ROM drive there should be a small pin size hole. Stick a pin in there to release the CD-ROM lock and it should open.
Jun 12, 2012 | Toshiba Samsung Slot Loading DVD+RW Slim...
I was burning copies of cds on my laptop, realized I had the wrong song list burning, so hit Cancel burn. It jammed up my computer. I shut down, but still cannot retrieve the disc that was being burned. I...
There should be a small pin-hole on the laptop's DVD drive. Find a needle or a paper clip and push it into the pin hole. This should either manually eject the disc or pop open.
If you do not have a pinhole on your DVD drive, go to My Computer > DVD Rom Drive
Right click on your DVD Rom Drive, and click "Eject".
This should remove the disc.
Hope this helped!
Jun 03, 2011 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
My benq dvd combo drive doesnt open how can i solve the problem
If you have a disk in there that you need and the paper clip option doesn't work then you will have to force it open, either way it's time to get a new drive.
note: there a hole by the button to open it with a paper clip
Feb 25, 2011 | BenQ CB523C CD-RW/DVD-ROM Combo Drive
The door wont open
there is a little hole near the eject button.use some pin and move it into dat hole.door will eject.then check wat hapend to connectors inside.
Nov 14, 2010 | Sony (CRX320AE/U) CD-RW/DVD-ROM (Combo)...
Need to remove a CD from DVD drive when computer won't reboot
In a laptop drive, there is a small hole in the door near the "open" button. Gently push a straightened-out paper clip into the hole and the drive will open.
In full-size drives used in desktops, the hole is usually under the tray. Again, push a straightened-out paper clip into the hole to open the tray. Once the tray slides out you can open it the rest of the way by hand.
Mar 12, 2010 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
I cant get my cd rom to open.. and I even hit the reset buttom and it wont open at all.. I dont want to force it..what should I do
ok take a sharp niddle... now you wil find very small hole near the open button on drrive
Dont worry insert niddle in that hole
that wil work
and your CD ROM wil get open
Mar 06, 2010 | Dell 48X Half-Height Serial ATA Internal...
My CD & DVD ROM drives will not open the door so I can insert a disk. The disk that is in the CD ROM that I can't get back out will play but the DVD ROM will not play anything at all.
Hello and Welcome to FixYa!
Your DVD rom tray may be stuck inside. Try the emergency eject by inserting a paper clip in the small hole at the front.
Regards,
Waqar
Dec 24, 2009 | Dell XPS 400 PC Desktop
My little sister was playing with the burner and then it just stuck! it wont come out and wont go in! i was wondering if u can send me a picture of the inside where the cd in put in! thank u soooo much!!!
Observe under the tray. (The tray comes out for the disk)
There is a SMALL hole. Just big enough for a paper clip to fit into it.
Take a paper clip, straighten it out, leave the last U-shape for a handle to hang onto.
Gently push the paper clip into the hole. Your tray will open. This is a manual override.
Oct 04, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
My cd-rom won't open
hi
if you get a paper clip or needle, you can insert it in the little hole on the left on the dvd rom and this will eject the cd from inside .
riz.
May 30, 2008 | MSI XA52P CD-RW/DVD-ROM (Combo) Burner
My dvd cant eject
You need to provide more information.
A CD-ROM/DVD drive only needs power to eject a disc. It does not care if the drivers are installed, for that function, it only needs power.
If this is a new drive it might be a bad one. If this is a drive you have used before, it might have gone bad.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
If this is new drive, make sure it is connected correctly.
Nov 10, 2007 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
Dell InspironTM 1501 Notebook Logo
106 people viewed this question
Alun Cox
