Question about Nokia 6288 Cellular Phone
6288 screen backlight does not lit!!!!!!
My 6288 back light does not lit when i slide it up....what happened? i asked the service center they told me its my lcd that need to be replace...but my lcd work just fine....so how?
  • bass junkie Mar 06, 2008
    I have the same prob with my 6288. after some investigation
    i found the prob to be a dodgy battery connection, specifically
    the middle pin. By fiddling with it I managed to get the backlight
    to work again. keeps stopping periodically though. so still need
    a permanant fix.... any suggestions?
Same thing just happened to mine. I fiddled with it a bit
and found it was the middle pin that connects to the battery!
bizzar i know.
Posted on Mar 06, 2008
I took the battery out for 10 seconds and cleaned off the dust and dirt from the phone. The backlight worked when l put the battery back.
Posted on Jun 11, 2008
Another solution... I just folded up a small amount of paper and rested it on the battery so that when the back case is closed there is pressure pushing the battery in (ie towards the phone's front). The added pressure on the battery brought my screen light back to life, saving me over $80! I was about to send it away for repair too!
Posted on Oct 14, 2008
Thanks so much, Mine was doing this ever since I had it put in for the ribbon to be fixed, but the battery terminal fiddling fixed it.
Posted on Mar 09, 2008
  • 490 Answers
Sir.may b the connection with the fone and the light module is just out...u need to to jst repair that thing frm nokia care.
Posted on Oct 18, 2007
Backlight setting does nothing to adjust my screen's brightness.
Control voltage to back-light should come from the main board. The main board to your TV should be troubleshooted. Contact any service technician; or the authorized service center. This is not a user repairable work. Very skilled one; indeed.
Electro help
Jan 22, 2015 | Televison & Video
You can hold a flashlite to see the screen, i was told it might be the light bar or inverter can you plz tell me what the problem is before i spend to much money
Ok if you can see the image when you show a flashlight to it means that the backlight is not working, it could be a simple problem as the backlight power cable loose inside or in worst case the backlight completely damaged. Best to take it to a service center and they will be able to tell you what happened. Hopefully it's just a loose cable.As LCDs do not produce light themselves they need illumination (ambient light or a special light source) to produce a visible image. Backlights illuminate the LCD from the side or back of the display panel.Backlights are used in small displays to increase readability in low light conditions.You can search for info on Backlight to learn more about it.
Jan 25, 2011 | Computers & Internet
I have a problem with my screen not showing up but you can hold a flashlite to the screen and see the image what do you recommend
Had my nokia 6288 mobile unlocked but when i insert new sim card it still asks for security code
there are many security codes...this one might be puk code...for that you will have to contact ur service provider...
where did u get it unlocked from?
Nov 29, 2009 | Nokia 6288 Cellular Phone
Black screen.
i face same prblm. but service person told some IC prblm.
Nov 03, 2009 | Nokia 6288 Cellular Phone
Cracked Nokia 6288 lens
just get it serviced from a a service center
Aug 05, 2009 | Nokia 6288 Cellular Phone
Nokia 6288 has gone dead
take it to the nearest nokia service center to flash the phone software
Jul 31, 2008 | Nokia 6288 Cellular Phone
Backlight behind numbers
in the case of your phone, you have to replace the keypad membrane of your phone, if you cant find a spare keypad membrane, you have to replace the whole flex. you can buy a flex in motorolla service centers near your place.
Jun 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
No lights in the touchpad when slide up
its probably the sensors inside your phone. most manufacturer uses magnet or sensing... if you can open your phone check if its still in place... if not visit your service center...
Oct 24, 2007 | LG KG800 Cellular Phone
Nokia 6288 Cellular Phone Logo
960 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
