Question about Toshiba Televison & Video
The 1/2 mute/mute button on my Toshiba CT-90255 remote finally stopped working after having to push it harder and harder to make it work. Now the channel review button is starting to act the same way. Can I fix these problems myself? Advice would be greatly appreciated. thanks, Bob
cammykins
  • 149 Answers
SOURCE: Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Posted on Sep 24, 2007
Kazong
  • 152 Answers
i have a ton of codes i need your model# of your Directtv Receiver.
Posted on Feb 05, 2008
SOURCE: Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Posted on Mar 20, 2008
SOURCE: toshiba CT-90275 remote
I have the same piece of junk remote and it has been slowly losing functionality over the last two months. Strangely enough, the only thing mine WILL do is scroll through the channels. Toshiba is about useless but if your TV is still under warranty, I'd call them and complain if this doesn't work. They are out of the remotes so plan on waiting awhile.
Turn off the TV and all the other things the remote is set up to control. Best to just leave that room altogether. Remove the batteries from the remote. Then, in turn, press each of the silicon buttons on the remote from top to bottom. Do NOT move the mode select switch at the bottom. Make sure you've hit each and every button. Replace the batteries and go try to see if it will work. Supposedly, this removes the static electric charges from the contacts under the buttons and will occasionally get the remote to work again. I had no luck at all. I've been waiting six weeks for a replacement and still no dice. The fastest way to fix the problem is to just go to an outside supplier and buy another one for $30. Then should Toshiba actually ever send you a replacement, you'll have one for the next time it crashes and burns.
I have a Toshiba 37HL67 model LCD and there is also supposed to be a firmware upgrade needed for those type models. The odds of that being the problem are so remote as to not be considered, but you never know. You will have to contact Toshiba to find the nearest repair dealer and have them do the upgrade. The upgrade is pretty simple. You unplug the TV, remove the cover for the card insert on the back of the TV, insert the firmware card. Replug the TV, follow the instructions on the screen, unplug the TV when it's done, remove the card, reset the little cover, plug in the TV and let it reboot. Toshiba guarantees that they will make the service guy come to you, but they usually are too lazy and want you to bring the TV to them. Toshiba will force them to do it, but if you can just get them to give you the firmware card you can download the instructions. Hope this helps.
Posted on Nov 18, 2008
The manual of my Toshiba TV says that you can reset it by pressing the "ON" pushbutton for five seconds and then the "TV" button. Do this two or three times and it resets. I think it's a pain in the ... but (no pun intended) what are you going to do? I tried to contact Toshiba but no answers yet to this nuisance. Good Luck
Posted on Jan 17, 2009
Tv button wont work
Check whether the panel lock function is ON. If it is ON, make it OFF. Refer the user manual to your TV for more details.
Jul 04, 2016 | Toshiba CT-90255 Remote Control
Where is the input/source button
The TV/Video button at the bottom left of the Toshiba CT-859 remote toggles between the TV and external video sources. This button is below the Reset button. The CT-859 remote works for several Toshiba TVs, including the 19A24. The manual for this TV describes the remote buttons on page 6. The manual is available online at Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/19A24-Toshiba-COLOR+TELEVISION-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0407309.pdf .
I hope this helps.
Jan 04, 2016 | Toshiba CT-859 Remote Control 72795473
My toshiba ct 8037 remote doesnt work only the 0,9,8,7 mute and volume up works ive tried pushing the tv button ive tried replacing the batteries ive tried literally everything please help
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control " in its search box at the top right of the display window to get the related post quickly.
Sep 04, 2015 | Toshiba Televison & Video
Ct90302, not working, what to check?
NON RESPONSIVE, CHANGED BATTERIES. CANNOT TURN OFF AND ON.
Oct 15, 2012 | Toshiba Ct-90302 Remote Control
My remote control is a model CT-90233. Several of
your remote is old and needs to be cleaned and rebuttoned(you can do this yourself) open up the battery panel and look for small screws to take of the case. you need to dust it out with compressed air. and reline the buttons. when you push down on the power button it probbaly is not making complete contact with the button, take a small thing and poke the power button without the buttons on. see if that works. if it turns on right away with direct pressure to the power switch then you just need to make sure your buttons are making complete contact. if that dont work then your circuit is screwed. you need a new remote or a new tv.
Feb 16, 2010 | Toshiba 32A30 32" TV
Programing my toshiba ct-90157 remote to a sanyo dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Toshiba CT-90157 Remote Control
Televison & Video Logo
373 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
