Question about Refrigerators
My whirlpool refrigerator (8 years old) is not cold and hums
My whirlpool refrigerator (8 years old) is not cold and is making a loud humming noise. The top freezer compartment is working, but larger bottom refrigerator is not cold. Can you advise?
    Problem Solver:
  • 12 Answers
Possible of 3 reasons.
1) Defrost bimetal is open and not allowing power to heater element in evaporator coil in freezer.
2) Defrost timer is not going into defrost, motor stopped moving.
3) Evaprator fan motor is not rotating. Possible motor.
First check for frost in the back panel of the freezer section.
if there is frost and the fan is operating, would suggest manually putting unit into defrost, depending on particular model. may be a switch you can move with a standard screw driver to get the fans and compressor to shut off. If you find this either. Top of fridge in refrigerator section below temperature selection controls. Or remove toe plate, the pretty decor under the door. and it will be in there.
If this is an electronic style, look under that toe kick and there is a technician's sheet that will explain how to get into defrost.
Allow 10 minutes for heater to heat, listen for water sizzling on heater element. if this does work. you will need the defrost timer.
Hope this helps.
Posted on May 14, 2009
    Sergeant:
  • 175 Answers
Hi..Sounds like one of the solenoids is acting up.Solenoids are
electromechanical devices that can be used to turn the water
to the ice maker on/off and also operate the door/screw that
dispenses ice.It could also be a fan or motor that is making
the noise.
check it out..
thank u..
kindly rate my response..
Loud humming noise
try using a spirit level to make sure unit is sitting square,the most common cause of noise.....(also make sure its not touching the wall....)
Apr 13, 2010 | Whirlpool ED2FHSS Side by Side...
Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge making a humming noise every 3 min
check and see if compressor is running it is in the rear behind the cardboard cover if it is super hot then you need to get a tech out to look at it and it may still be under warranty
Jan 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Nov 16, 2008 | KitchenAid KGYS850LT Gas Dryer
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Mfd2561hes Maytag Refrigerator
This sounds like you have a Maytag Ice2O. You need to find out if that cound is a relay/overoad failure on the compressor or the compressor going out. I can say from experience that some of those have a tecumsie comprossor in them and the do tend to fail. If you hear a loud electrical humming sound coming from the compressor and your getting a warm up then you need to record this sound on some kind of sound recorder and call a Whirlpool warrenty certified tech. out to look at it if it's less than 5 years old from perchase date then Whirlpool will pick up the part and labor bill of a compressor installation also check your owners manual for warrenty details. Hit me up let me know.
Feb 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Loud Humming and Hot Front Panel
DONT TOUCH ANYTHING. IF IT IS COOLING CORRECTLY LEAVE IT. LOUD HUMMING IS COMMON ON SOME COMPRESSORS.(ANNOYING I KNOW).THE HEATING ON THE FRONT IS NORMAL AS IT IS THE MULLON HEATERS WHICH RUN THROUGH THE FRAME. IF THAT AREA WERE COLD, CONDENSATION WOULD OCCUR AND WOULD DRIP CONTINUOUSLY.
May 31, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
318 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
