TV shuts off on it's own. Turns on fine, stays on for a few minutes, then something clicks inside, and it shuts off, and can't be turned on with remote. I then spend the next 5-10 min turning it back on while it keeps shutting itself off.
  • cren May 14, 2009
    Well, I've been looking up this issue, and for the trinitrons, it appears to be a reoccuring issue. I'm trying to track down specific methods and means to fix this, although I suppose it if costs more then 100 bucks to personally repair, then it's not worth it. The TV has been used for old video games and for the VCR.
  • cren May 17, 2009
    I looked up the various parts needed for the exact problem, and even borrowing the correct tools, it's not worth it in the end. It's a shame, a good set I've had for 19 years, one of the best pictures available, and yet they all come with the same defect. A junky RCA that looks like a fishbowl will last much longer simply because of that. The set is in the car, now all I need to do is find a proper recycling place that will take it. Most people will just dump the things into a dumpster. Thanks for the advice.
  • 3,866 Answers
This is because of a power supply unit going out inside and there is not much you can do accept for have it repaired or think about new at this point also with the new digital tv standars comming out you are going to need a box for this if you doing OTA anyways so at this point if you are not inclided to haing it repaired have it recycled.
Posted on May 14, 2009
  • Grand Canyon Tech
    Grand Canyon Tech May 14, 2009
    Well then if your tryingto fix it yourself it would be a little hard tracking down parts for replacment and giving it to a salvation army will be FREE to recycle. Bestbuy had buybacks for recycling check them out and see if your TV can earn a few extra bucks!!
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
I have a 2001, Panasonic 27
Suspect either bad solder connections somewhere or a issue in the power supply of the set----set will shut down for a number of reasons--it monitors voltages inside and if some go high or low it will shut down.
May 16, 2012 | Televison & Video
TV will not stay on. It will turn on and after a
Problem with your TV's picture tube,Replaci it
Feb 15, 2011 | Philips 32PT5441/37 32" TV
Just replaced lamp a week ago and tv worked fine
2 things will cause this Lamp is defective, or Fan to lamp quits running this will shut TV OFF, if the fan quits running while Lamp is on it is design to shut Lamp Off to prevent Damage to Lamp IF Fans are ok It will be the Ballast board It is what turns Lamp on.Look on E-Bay for Ballast board if it turns out thats what you need or call Encompasss Electronics 1-800-638-3328
Sep 19, 2009 | Toshiba 62HM95 62" DLP HDTV
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
lost my code book need the code for a phillips universal remote for a konka tv.
Oct 19, 2008 | Philips Magnavox Learning Universal Remote
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
408 people viewed this question
Top Televison & Video Experts
Electro Med Services...
