Is it an anti theft radio?you may need a code for it.
turn the radio off and then back on.a disc may have been jammed halfway with trhe battery problem.
bang it lightly
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Take a paper clip and bend a small portion of it so it is straight and push it in to the CD slot trying to make it on top of the CD. Push the eject button and whiloe it is trying to eject the disc try pulling it out with the paper clip. Pull a little bit and then set it up and again. Eventually you will catch the center of the disc or have it out enough that you can poull it out.
it started and stopped the cd player in the middle of all that kyoss now it doesn't know that disc are in there.. in plug the power source and plug it back in that should kick them out..
good luck ray
had to replace player twice, luckily it was under warranty. FACTORY PLAYER JAMS EASILY !!! What I have learned is to put cd player in radio mode before ejecting instead skipping form disc to disc.
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
