Question about Sylvania 6419TA 19" TV
My tv will not show channels about the channel 13, everything else is just static.
  • ess91biker May 14, 2009
    how do you manually tune?
2 Suggested Answers
maatmartin7
  • 1216 Answers
SOURCE: model SSL2006 will not accept TV (cable) channels
You must be sure you are in connection with the menu. Read the menu and find [video source] antenna/cable. Be sure you are in "cable" source. And then program your TV for channel search! Try this, and thanks for asking!
Posted on Oct 06, 2010
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Trying to connect with Comcast using comcast remote. have idetified correct code and and can turn TV on & off with remoet but can not get channels to change .... just get static no picture ??? Can...
The Comcast remote only changes channels on the cable box. not the tv itself. If you have a cable box then the tv will need to be turned to channel 3 or 4.
Apr 11, 2011 | Quasar VV-1302 13 in. TV/VCR Combo
The tv is connected to Dish Network as TV2. I accidentally changed the channel & now I can't get it back to channel 90 - it only goes to 13 now. How do I fix this?
In the menu screen, you must find antenna connections. For example " TV Air "(over the air channels 2 through 13) or cable TV. You must tell the menu to select cable TV (with the original remote). This will allow you access to channel 90. Thanks for asking and show a few hands of support.
Nov 07, 2010 | Orion STV2763 27" TV
Will not show anything but static
Make sure the TV tuning mode is set for "cable". This will be somewhere in the TV's setup menus; check your manual for all the details. If it's set for "air" as I suspect it is, only the first 13 channels will be found when connected to cable. Channels 14 and up don't get tuned in on "air". Once you've set the TV for cable, rescan channels and you should have 'em all.
Thanks for asking here. If this solution has been what you needed, please take a moment to rate it!
Mar 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
Not all channels available
Sounds like a bad tuner or more commonly the connector on the tuner is loose and or broken.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
May 12, 2008 | Televison & Video
Can't get cable channels, only goes up to ch. 13
First check and see if you are on Cable or Ant. It sounds like you are on ant. Change it to cable. If you are on cable then it's you tuner, you need to replace it.
Sep 14, 2007 | Zenith A25A23W 25" TV
Picture problem when I use an external antennae
You cant unless you have been trained to trouble shoot solid state electronics as this set has no user serviceable parts inside and is best left to the pro tech to service. good Luck
Aug 08, 2006 | RCA F27645 27" TV
Sylvania 6419TA 19" TV Logo
56 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
