Question about Zanussi FJS1225W Front Load Washer
Zanussi front loader
Stops after main wash, wont rinse or go any further
Checked pump and filter both ok
heater is ok
to empty skipped programs and drained
  • Anonymous Nov 12, 2007
    Programme runs , but machine stops full of water. If I select drain, it empties and spins OK.
  • Anonymous Dec 16, 2007
    heater is ok
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Posted on Jan 02, 2008
My asko regardless of selected wash program stops after the main wash, it will drain the water, but then not start the rinse cycles. The washing machine will allow you to open the door. I thought it was...
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Also please note
with the Asko there are several possible things that can interupt the cycle either during wash or drain/spin. Have you checked the pump insert/button trap for debris or obstruction of any kind ? ( below main door to the left ) Are you using "he" ( lo-sudsing ) detergent ? Does the machine provide any error code, i.e. If it's a mechanical timer model does it stop at "C" or "S" or if electronic a symbol in the display ? Will it complete a cycle without any items in the basket ( empty ) ? Will the unit rotate in both directions and will it spin if you try both parts of that specific cycle ? This will help determine if the problem is with the drive motor brushes.
Nov 29, 2010 | Asko W6021 Front Load Washer
Washer would not drian nor spin
no the solution is that the drain pump is dead and needs to be replaced open the front panel of the front loader and locate the filter and clean and also remove!!
Aug 20, 2010 | GE WSXH208A Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Error code f 05
this worked for me and I made 25p for the trouble:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Mar 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
WASHING MACHINE FRONT LOADER
If it's similiar to the F1231 w than i found a color catcher caught between the pump impeller and pump cover. this is located at the bottom right front of the 1235W and flips open. grey hose beside it pulls out and remove cap of hose and drain into bowl.
Tip take wet clothes out of machine to speed up the emptying of machine - this dawnwd on me after a few minutes.
Some more water will come out when you remove the pump cover - screw anti clock wise.
ee pages 18-19 of the zanussi guide for cleaning instructions. I found this link to manual on internet
http://www.manualshark.org/manualshark/files/6/pdf_13638.pdf
or check your own manual for cleaning instructions and remember unplug power first - just in case. you may need to reset your wash to do a rinse again as i got a vibrating sound when i restarted and skipped to spin. hope this helps
Dec 31, 2007 | Zanussi Washing Machines
Machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
91 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
