Question about Refrigerators
Master mind fridge not going on auto mode - Refrigerators
    Sergeant:
    Champion:
  • 214 Answers
Switch off your refrigerator for at least 8 hours......and again switch it on. if this problem is not solve than contact your service authority. the problem is in your master mind circit (front panel)
Posted on May 14, 2009
It will not turn on.
First thing, disconnect AC and DC power. You can leave the LP attached but go ahead and close the valve for now.
Plug in AC only and let it boot up. If the fridge does not automatically, press the power button to turn it on. The refrigerator should start working. Let it run for a while to make sure it does get cold. Once you confirm it does work you can either unplug the fridge or just open the breaker in the fuse panel.
Before you reconnect the DC wires, you need to check the power coming in. Most camper units will have wiring that will have color on one side and white on the other. The color wire will be your 12VDC, white is neutral return. Once verified, pull out the fuse for the power to the fridge to isolate the DC voltage. Check with the manual for the fridge, the positive input should be marked or identified in some manner. Open the valve to let LP back into the lines and wait a few minutes. Plug the fuse back in. If the fridge does not turn on automatically, press the power button to turn it on.
With the DC power on and no AC detected, the display should display CHECK. Let the fridge run for a bit to make sure it cools. Once you know it is working, the breaker for the AC can be closed to turn on the AC power to the fridge. Press the MODE button until AUTO displays displays.
Let it get cold and resume normal operations.
May 10, 2016 | Atwood 6 Cubic Ft RV Refrigerator Black...
Dell Studio 540 will not start shows black screen with parameter error message
Not very helpful info! I would try tapping f12 on booting up which takes you into the Dell Diagnostics mode. Then come back here.
Feb 24, 2014 | Dell Studio 540 MT Pentium DualCore E5300...
Fridge worked fine last camping season, this year light comes on in the fridge in AC mode, but won't get cold. It is a 3 way fridge in our motorhome, and we have always used it in electric mode only. I...
Also keep in mind that these units are very sensitive to being leveled; even a minor tilt will cause them to quit cooling. These units are not equipped with compressors as are home refrigerators which are not quite as fussy as the evaporative type.
Aug 04, 2011 | Thetford Norcold RV Cooler/Freezer
My fridge doesn't stops defrosting.
Please chut off your set for about 8 hours and connect once again , if you notice good cooling initially and later it starts to come off, then there is a possible fault from the compressor , to the thermostat to the auto timer and for low gas or gas leak. You will need help to check for the compressor start up current using a clamp tester, check for gas leaks, check for thermostatfault. keeping all this in mind, get an estimate from the nearest service shop. Decide and go forward only if the cost is reasonable. If not I suggest presuming your fridge is more than 5 years old to change over for an new model with high energy saving, extended warranty and trouble free mind. Hope my adivce helps.Good day
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Just bought a used LG gc-051ss mini fridge. The freezer part seems to turn itself on on off itself. It doesnt remain in its freezing state and is always defrosting itself and dripping water in the...
There is a self timer for auto defrosting in the no frost model. There could be possible fault in this setup. Also your thermostat could be another culprit. You will need to call a service technician to give an second opinion but keep these views in mind. Never try to do any work which could be expensive to already a wrong choice of buying a used set w/o warranty. Finally keep your thermostat in diffferent modes and check out for any differance in the fault. Hope my advice is helpful. Good Day.
Jul 02, 2010 | LG GC-051SS Compact Refrigerator
My mother has this model: Fridge Westinghouse Auto Defrost 391. She thought that she would not have to manually defrost it and yet she does because ice builds up in the freezer. Should this be...
If water is building up in the freezer it is not going into a defrost mode. Defrost imer or defrost term switch. You need a service tech to check it out but giving the age of the refrigerator You could buya new one for a little more than it would cost to fix. It would be about 200.00 dollars for repair. You could ask for free estimate before you make up your mind, Rus
Nov 29, 2009 | Refrigerators
Auto focus doesn't auto focus
So you having problem with AF problem?
Try this (mind your camera to protect it from dust OR another small parts to get in while you opening):
1. Re-connect the lens and the camera.
2. Make sure the connectors is clean.
3. Connect it together again.
Hope this will help! Any questions? Feel free to PM me =]
Jul 07, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Reset Norcold 'N61 Series' Fridge after lockout
Hi Lynn1965,
I'm Harvey the Master Plumber.
Yor problem is: Please help! Your brother phoned you on his cell from up north. He's supposed to go hunting tomorrow, and is having problems with his fridge. The nearest dealer is 5 hours away, and he's very upset.
The fridge went into lockout mode after accidentally resetting twice. Now, the lights flash, and fridge doesn't work.
Please advise how he can fix this problem himself. You both would greatly appreciate it!!
First, unplug the unit for 10 minutes. That should reset it. If not, ask if he can here the compressor motor. If not, then he has a compressor or electrical failure inside. If yes then look to a bad thermostat.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Thetford Norcold® Model DE0061
Master hard disk s,m,a.r.t.status bad,backup and replace
A failure message from the SMART system of this nature indicates that a catastrophic hard drive failure could be imminent. Without delay, back up ANY data you want to keep. This error isn't going to go away, and is being reported by the drive controller.
Whilever you can access the drive, move any data you want onto another media (such as DVD or external USB hard drive) because chances are it's not going to work much longer. You need to look at buying a new hard drive as soon as you possibly can, and migrating the data to it.
Files and Settings Transfer Wizard will be able to backup your data to another media.
Jun 02, 2008 | Computers & Internet
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
