Question about RCA HD61LPW42 61" Rear Projection HDTV
I have a RCA HDLP5W151. The red and green color no longer shows? What do I need? I have gone in and fixed te colors on the color guide, but it fades out in a day or two. I loose the red and green colors again. The blue and yellow comes through perfectly. Sometimes it gets very dark.
techman
  • 3130 Answers
SOURCE: 56 projection t.v. color problems
If you mean they are separated like a 3-D effect, then you have the typical bad convergence IC problem. There are two IC's mounted on a large metal heatsink, they will have STK392-###, the ### being differant models of TV sets. these are soldered into place and are no usually replaced by the user, unless you have solid state repair experience, knowe how to solder, have a schematic on the set, and know the High voltage safty factors of projection TV serviceing. If you have no experience, please play it safe, and get someone who is trained to service TV sets. Good Luck Please do not forget to rate this thread.
Posted on Dec 08, 2006
  • 61 Answers
SOURCE: color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Posted on Mar 07, 2008
  • 4 Answers
SOURCE: distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Posted on Aug 03, 2008
ladywinn
  • 5138 Answers
SOURCE: I have color misaligned in my RCA HD52W59 tv. I can see three
Go to menu then setup if you do not see convergence in the menu then you have a Blowed Fuse FL231 its on right side of FBT flyback transfomer will be 3 small brown looking caps But are fuses it will be the one in the Middle! Go to Partstore.com Look for FL231
Posted on Dec 03, 2009
SOURCE: RCA 52" projection tv convergence problems,can i fix it?
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Posted on Mar 31, 2010
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
I put the 5fr red velvet hair color in my sisters hair with a red intensifer and its washing out can you tell me why
you need to leave it on longer. Red fades quickly try using joico cuticle seal after coloring . after coloring try to just rinse out color, don't use shampoo spray the cuticle sealer on the hair and don't wash hair for 2 days..it should keep it from fading so quickly.
Jul 08, 2011 | Joico VeroColor Permanent Hair Color 5FR...
Black Crayon marks in lt colored couch and floor
try using a cleaner called goo-gone, it disolves a multitude of different oil and wax based staind and marks I use it to remove gum from a dark green couch and then a white carpet. Both stains are gone no residue, it has a citrus smell that fades with regular soap and water after te stain is gone.
Feb 11, 2011 | Garden
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Infocus 61 inches DLP-HDTV.
Infocus was always made by RCA for infocus the parts are straight RCA be warned that the parts for the RCA dlp's are very exspensive
Mar 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Blue color gone
This sound like the color wheel needs to be replaced!
That should fix ya!
Dec 17, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Blue, green, and red colors all off
I would suggest having a repair person come out to your place to fix this problem. I believe the convergence IC are going or have gone bad. I would estimate a $300 - $400 dollar repair bill.
Sep 22, 2007 | RCA P46921 46" Rear Projection Television
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
RCA HD61LPW42 61" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
