PC problem Sir, In my computer if I connect any USB device to any of the USB ports it immediately becomes write protected. I can't move any file/folder to any where. My virus scan says 'no threats detected'. Please tell me wht to do now. I have already spoiled one USB drive in the process. The device which becomes write protected shows the same status in other computers also! Pl. help! My computer config. is: Intel dual core 2.4 GHz. 3 GB RAM, 8400 graphic card 250 GB HDD Loaded with Wibndows XP (provided by assembler)
  • 23 Answers
I'm not sure if this will work, but you can try and uninstall your usb drivers and reinstall them: right click "my computer," -manage, -device manager,-select "universal serial bus", and uninstall the drivers on all of them. Windows should automatically reinstall them after detecting them. This worked when my laptop crashed everytime I plugged any usb in.
Posted on May 14, 2009
  • 355 Answers
There is a simple solution for this in the case of windows.
Just do a "regedit" for StorageDevicePolicies key.
. Get into the Registry - Press Start -> Run, enter regedit, press Ok
. Click on My Computer. Then press File -> Export, give some file name to backup the registry. Just incase you ever need to rollback.
. Navigate to HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control/StorageDevicePolicies
. In the right pane select "writeprotect"
. RESET the value to '0'
Repeat the same for ControlSet001 and ControlSet002 incase they exist.
Now plug in your USB drives and it should work. Else just reboot the machine and try.
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
I can't import the photos from my camera to my computer
1.turn on your PC.laptop
2.connect USB cable provide from camera USB port to PC/Laptop USB port
3.turn on the camera
4.PC/Laptop will detect new devices automatically
5.for some cases, the computer might ask for devices driver (inside CD/mini CD inserted in the box)
6.after the installation suceed, you can browse/move files from camera to your computer
Jan 04, 2011 | Samsung Cameras
I have Nokia N 72. whenever I connect with cable to USB port it popups a massage "USB device Not recognised". Before Few Months , it was working properly. and other mobiles and USB devices are...
sir plz install the n72 pc suit to the computer.and then connect the data cable from phone to the pc to transfer the files [or] change the data cable for proper connectivity from phone to the pc.................
Dec 07, 2010 | Nokia N72 Cellular Phone
Please can you send me detailed instructions on how to use a kingston usb memory stick
The memory stick becomes another drive, when plugged into the USB port. Some sticks have a write protect, which is a teeny tiny switch. If the switch is in the protect position, you can read but not write any data to the drive. Often the drive will be listed after all of your camera card ports.
To view the drive press and hold the Windows key and press the letter E. and then release both. The available drives should show up there.
Nov 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
When i ever i connect my blackberry 8100 to my pc it demands drivers, how can i get this solved
insert the disc that comes with the phone and run it. this should install all necessary drivers for you but if you dont have it, you can go online and search for the drivers.
Nov 05, 2010 | RIM BlackBerry Pearl 8100
FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive: SIR i hav connected my frnds seagate 500gb externa...
WHat you could do is test other usb ports on the system or you will have to remove the drive from the caddy and install it as a slave inside your pc and see if you can access the data,
If you can then you know its the caddy at fault
Here is another possibility that i found on another forum
"I was playing around in Device Manager, unplugging and replugging the hard drive. Finally I found that although it wasn't listed under Disk Drives or Removable Storage
, it was listed under USB controllers. It had a little x on the icon. Upon right clicking it I found that it had somehow become disabled on my computer. I'm not sure how that happened. I know I didn't do it."
or you can try this
Try this fix for missing usb ports by JohnWill
Create a file with NOTEPAD containing the following lines and save it as FIX.REG
-------------------------- Use text after this line --------------------------------
REGEDIT4
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
"DEVMGR_SHOW_NONPRESENT_DEVICES"="1"
-------------------------- Use text before this line --------------------------------
Double click on FIX.REG and say yes to the Merge Into Registry question.
Unplug ALL USB devices.
Open Device Manager.
View, Show Hidden Devices.
Uninstall all devices under USB Controllers.
Uninstall all devices under Disk Drives that you know are not present.
Uninstall all devices under Storage Volumes. Say no to any reboot prompts until you are finished. Also, if a Storage Volume doesn't uninstall, ignore it and move to the next one.
If you have a yellow ? with unknown devices, uninstall all of the entries there as well.
When this is done, reboot TWICE.
Reconnect the USB devices and see if they're recognized properly.
NOTE: If you have a USB keyboard and/or mouse, you'll have to modify the instructions and leave enough parts for those to function.
May 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
Pendrive
You need to install drivers for USB. Also driver file for detecting your pen Drive for Windows 98.
Best Regards
Rafique
Jan 01, 2008 | Epson LX-300 Matrix Printer
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
