Question about Sony PSone Console
Timer how can i connect an external coin operated timer inside ps1 console so that the controllers wont work when it runs out of time but does not turn off the game? thank you..
  • 709 Answers
Hi Iyot,
I am sure I could help you with this.  Please contact me through my website contact info at www.playstationclinic.com I really need more information about your coin operated timer.
Posted on Oct 18, 2007
I have a coin operated timer control box for my washing machine. Someone turned the power off at the wall and now it won't work
Please confirm if the power was restored. Now If so then you can turn it off once again and wait for few minutes before switching it ON. Tap on sides while the machine if switched off to confirm if any coin was lodged while the power was off. If this is struck within you will need to remove the covers to clear the mechanism and reset the sensor action. Also check if there is power supply within the unit for the functioning of the control board.
Jan 25, 2013 | Washing Machines
Hey, do you know, in my country Malaysia we got someone that can upgrade PSOne console to be able to play PS2 console game :) but I wonder, how they do that...?? That the problem, and I wish someone who...
The only way someone can get a PS1 to play PS2 games is if they modified a PS2 to look like a PS1. The hardware inside a PS1 is not powerful enough and not complex enough to run PS2 games. They would need to take a PS1, and take the insides out. Then take the insides of a PS2 and modify it so it functionally fit inside a PS1. This seems like cool albeit pointless way to modify your PS1 and PS2. Thanks for the question!
May 30, 2011 | Video Game Consoles & Games
Whirlpool dryer model LEQ8858JQ0 - won't turn off by its self, just runs and runs no matter what cycle it is on.
You can perform some Whirlpool electric dryer timer troubleshooting to determine if the timer is faulty or if the cause is somewhere else within the dryer.
  1. Access the Timer
    • Unplug the Whirlpool dryer power cord from the dryer electrical outlet. The timer is inside the control panel on the top of the dryer. Pull the dryer away from the back wall so that the control console can be raised without hitting the wall.
      Remove the single screw on each end of the control console that secures the control console housing to the top of the dryer. Grab the sides of the control console and raise the front of the console up and toward the rear of the dryer. With the control console in the service position you will now be able to test the timer.
    Test the Timer
    • Locate the dryer timer inside the control console. It will be directly behind the dryer timer control knob. There are two wires that connect from the dryer to the dryer timer. Place a piece of masking tape on each wire and write on the tape what terminal each wire attaches. Use a pair of needle nose pliers to remove the wires from the terminal ends on the timer.
      Set the scale on a volt-ohm meter to the RX1 setting to measure the ohms of the timer. Place one probe to one terminal and the other probe to the remaining terminal. You should get a reading between 2,000 ohms and 3,000 ohms. If you do not get this reading, replace the timer.
    Replacing the Timer
    • Pull the control knob off of the timer shaft on the face of the control console. Remove the two screws that secure the timer to the inside of the control console. Pull the timer out and take the timer with you to an appliance repair facility. Compare the new timer to the old timer to make sure that the mounting screws match.
      Place the new timer inside the console and secure the timer with the two retaining screws. Attach the wires to the timer and remove the masking tape from the wires. Lower the control console and reattach the console to the top of the dryer with the retaining screws. Push the control knob back over the timer shaft. Push the dryer back against the wall and plug the power cord back into the electrical outlet.
Apr 18, 2011 | Whirlpool LEQ8000JQ Electric Dryer
Getting a disc error when turning on the ps2 with ps2 games, but it works with ps1 games...!
Theres a wheel in the disc drive that controls the elevation of the lens. To mod your ps2 to read burnt ps2 games ONE would alter the height of the lens by adjusting the wheel ever so slightly. There are online tutorials in the precise adjustments for different disks. (one height reads only ps1 games, another height reads ps1 and ps2 games, and one more height reads ps1/ps2 and burnt ps1/ps2 games) Your best bet would probably be to just purchase another ps2 used, but if you want to do it yourself, you can.
Oct 03, 2010 | Sony PlayStation 2 (PS2) Console
I have a Kenmore gas dryer model 97591220. wont
Disconnect power to the dryer and remove the screws attaching the console rear panel to the console and pull the panel off.
Inspect the wires connected to the timer and ensure a snug fit connection. Clean the connectors and terminals then reseat it several times to ward off dirt within the connectors.
Reconnect power to the dryer and start it; replace the timer (part number 3398195 ) if the dryer still won't stay running. Unplug the dryer and pull the timer knob off the console. Remove the screws securing the timer to the bracket and remove it. Secure the new timer in place then disconnect the wires from the old timer one at a time and connect it to the corresponding terminal on the new timer.
Push the timer back into position on the console and secure the console rear panel in place.
Apr 14, 2010 | Dryers
I cant play my ps1 because it doesn't read the games but the games are working with other ps1
there is an "eye" like thing inside it, try to fix your ps1. you must not touch that because the eye reads the games
Mar 13, 2010 | Sony PlayStation Portable (PSP) Console
Coin-operated dryer won't turn off at end of cycle.
A dryer timer is a real simple device. Take the whole thing out and give it a good inspection. A little wd 40 can do wonders. A bad coin in the works can jam it on. Put a coin thru the works, watch the action. The timer motor can fail or get stuck, spray and test.
Apr 22, 2009 | Maytag PYE2300AY Electric Dryer
Timer devices
hi im roland from the philippines,,by the way about your problem to know how to install a coinslot timer,,its so easy bro CONNECT the coinslot & timer (red & green)into a ground of keyboard(yellow )& mouse(green) to detect the coin and running the timer <,rol13land@
Mar 21, 2009 | Video Game Consoles & Games
Ps2 slim, plays ps1 games but wont play ps2 games
umm maybe something is wrong with the ps2 or is it getting to hot???
Dec 28, 2007 | Sony PlayStation 2 (PS2) Console
Can't read my disk, grinding sound
they are a compaq format. some ps2s only read dvd rom formats. check the back of the cd case
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Sony PSone Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
