Question about D-Link DI-704P Router
How to setup password?
How to setup my password for my DI-704P
  • 1 more comment
  • Shishir Garde
    Shishir Garde May 11, 2010
    Can you please let us know which password are you talking about? Is it the one which will secure your wireless connection?
  • timothy_ruiz Jun 05, 2010
    how to find the password if i forget the password in Dl-704P
    the password when i go to Dl-704P site
  • 611 Answers
Just enter this device with the help of internet explorer or Mozilla etc browsers the type in address bar default ip address like this 192.168.0.1 or some this ip address is give in the cd which came with box after then they ask user name and password you have to give default user name and password after you given this you got the stauts page then go to the mantanice or administrator or system tools like that one option is there in the lift hand side of the page click it then you get the user or password or admin option just click on it then change the password.that's all.after the change the password you have to save it.and reboot the router
Posted on May 14, 2009
  • arronjet2009 Aug 05, 2011
    If it doesnt work try restarting or reinstalling the router.
What is the default username and password for DI-704P router
Try the ID of 'admin' with a "blank" password.
Try a "blank" ID and a password of 'admin'.
Oct 10, 2010 | D-Link DI-704P Router
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
D-Link DI-704P as wireless
Yes, you have to. The router model mentioned is not a wireless router, not unless you have other network device there that transmits wireless connection such as a wireless access point.
Jul 05, 2009 | D-Link DI-704P Router
I have a DI-704P which is locked with a code. I have a new computor. How do I connect to the router?
Open a web browser:
Default IP address: 192.168.0.1
Default admin username: admin
Default admin password: <blank>
Happy configuring!
Dec 27, 2008 | D-Link DI-704P Router
Username and Password
Factory defaults on a 704P is
Username - admin
Password - <blank>
Factory defaults on a 704 are the opposite
This is factory defaults, if someone has reset it, you will need to restore the factory defaults in the router.
Aug 18, 2008 | D-Link DI-704P Router
Add di-704p to an existing network
What you want to do should be quite easy:
1. Just connect one of the LAN ports of the DI-704P to a LAN port of your WRT54G. Try using a standard network cable. If the port status lights does not turn on on both sides when you connect the cable, use a "crossover" cable. Important: leave the DI-704P WAN port empty.
2. Disable the DHCP server on your DI-704P, your WRT54G will be the DHCP server.
3. Assign a static IP address to you DI-704P, different from your WRT54G. Example, if your WRT54G has 192.168.2.1, you may assign 192.168.2.4 to your DI-704P. Make sure that the IP address you assign is outside the DHCP range configured in your WRT54G and that the subnet mask is identical on both.
You will then be able to use your print server from any wired and wireless computer and the remaining LAN ports both on the WRT54G and DI-704P.
Feb 18, 2008 | D-Link DI-704P Router
Sympatico & DLink DI-704P
It usually is simple, and hopefully the answer is as well. If you haven?t already done so unplug the modem and the router. Wait for a few seconds and then plug the modem in followed by the router. Reboot your PC and try the Internet again. If it still doesn?t work then I would try doing a hard reset of your router and reconfigure using the setup process outlined by the manufacturer. If that still doesn?t work let us know and we?ll continue ?.
Jan 01, 2007 | D-Link DI-704P Router
Factory setting
Step 1 Power the unit off by unplugging its power adapter. Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure. Step 3 Power the device back on by plugging it in. Continue to hold the reset button. Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button. The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in. If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
Feb 16, 2006 | D-Link DI-704P Router
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
D-Link DI-704P Router Logo
166 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
