Question about Car Audio & Video
How set clock dual xhd7720
How to set clock from 12hr format to 24hr format
  • taylor5643 May 14, 2009
    the clock is set, but i have no control to find the submenu, it doesnt ask to link into a option.
    Sergeant:
    Champion:
  • 255 Answers
There are ways in setting the time format.first,set time.if ask to what time format,choose 24 hrs.sometimes there are submenus,but it all starts with clock.
Posted on May 14, 2009
How do I get my tv off of military time ?
Would be best to have the TV make/model, but generally the clock settings will refer to clock "format", and you will find this using the remote.
Something like this.
http://cdnimg.thehonestreviews.com/ZoneShieldClockSC8000-image3.jpg
You need to change yours from 24hr. to 12hr.
HTH
Mar 19, 2015 | Military Time Watches
Jensen jbd-100 change clock
Take battery out and unplug to force a reset.
Hold Display until it starts flashing 12 hr
----use tuning buttons if you need to change that to 24hr
Tap Display to confirm setting and move to next stage
Repeat the same steps of tap Display and then use tuning to adjust up or down for the hour and minutes.
Make sure to increase hour setting enough to have the "pm" show up for times after noon when using 12 hr format
Nov 06, 2013 | Jensen JBD-100 UNIVERSAL BLUETOOTHR CLOCK...
How do you change time from 24hr. to 12hr.
GO to clock settings.
turn autoupdate off.
exit menu
go back to clock settings.
select time format preference
exit menu
turn autoupdate back on.
May 07, 2011 | Motorola Mobility RAZR V3
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
How can i get the houses of parliment with big ben on my phone it show day light with birds and dark blue with fireworks at night
Ensure that you have he phones clock set to the correct time. The application needs to have am/pm set or the time set correctly in 24hr clock format to work.
Jan 16, 2011 | Samsung SGH-S5230 Cell Phone
After a power outage, my Bose radio went to military time. I've tried to re-start it by unplugging, re-unplugging, etc. Help!
To switch between 12hr and 24hr format:
1) Turn your Wave Radio off
2) Press and hold "Clock Set"
3) Press "On/Off" to switch between 12hr or 24hr format.
Dec 27, 2010 | Bose Wave Radio
Setting clock in 12 hour format instead of 24hr
You can download the manual here: www.topeak.com/mediafiles/assets/341/file/1
By performing a reset and setup under section A. of the manual you can select 24 or 12hr time.
Jan 06, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
How to set the clock on a Sanyo DC-DA1100 stereo?
This is taken from the user manual.
If switched on, press the ON button to turn the unit off.
Press the CLOCK/TIMER button for at least 2 seconds so that the clock icon blinks on the display.
Press the MEMORY button. The hours display blinks.
Turn the VOULUME control to set the hours.
Press the MEMORY button. The minutes display blinks.
Turn the VOULUME control to set the minutes.
Press the MEMORY button. The clock starts.
NOTE: the time can be set accurately by pressing the MEMORY button when a time signal is heard.
Changing the clock to 12 hour display.
When the clock is display, press the MEMORY button and hold it, then press TUN UP buttom (this will change from 24hr format to AM/PM format)
Nov 02, 2009 | Sanyo DC-DA1000 CD Shelf System
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
Don't know how to set alarm clock or timer - have set clock OK
To set the Time all you have to do is hold memo/c.adj while on standby, the screen will flash 24hr if you press tune it will flash 12hr pick weather you want 12hr or 24hr and then press memo/c.adj to set the hours press tune then hold memo/c.adj to get to the minutes and then press tune to get the minutes set
May 03, 2009 | Audio Players & Recorders
Car Audio & Video Logo
156 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
