Question about Desa International Reddy Heater 200,000 BTU Kerosene Forced-Air Heater #R200BT
I have 200000 btu heater that makes hummking noise when plug it in and will not heat up and blows breaker, also have 115000 btu multifuel heater that turns on heats up for second but shuts off what is the problem with these.
5 Suggested Answers
  • 50 Answers
SOURCE: Heater shutting off
It was suggested I clean the pilot. I bought pipe cleaners and cleaned the pilot and now it works as it should. Thank you for the help.
Posted on Nov 18, 2008
  • 58 Answers
SOURCE: fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Posted on Jan 17, 2010
SOURCE: I have a glow warm 20000 btu natural gas unvented
well, these heaters are typically thermostat-bound, and I have found that they simply will not burn continuously, like a blue-flame heater. Try turning up the setting--this will make it come on/off more often, effectively heating at least one med-lg room, and partially for adjoining areas. Keep in mind that these only rated for 700-1500 SF--that is NOT the floor measurements, but square feet of airspace; eg., a 10' x 15' room has 10' x 15' x 8' (8 foot ceiling) =1200 sf. That said, My 15k btu wall unit had been the sole heating source for my entire home for 5 years, until last year, when I acquired another smaller unit. However, I typically only use a few rooms, and shut off unused areas (ya, was 'cool' in unused back room areas).
Posted on Jan 19, 2011
heatman101
  • 43501 Answers
SOURCE: My Kerosene torpedo heater starts
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Apr 02, 2011
Tip
How to heat a garage or workshop
Two things to consider in buying a space heater - the require BTU and the electricla cost to heat your space.
You can go here to calculate your estimated BTU need - http://www.calculator.net/btu-calculator.html
or just look up "BTU calculator' on line and there are other BTU calculators as well.
The BTU is what is pretty much required to effectively and efficiently heat to the temperature range you are comfortable with. It's a matter of the maximum degrees you want to raise the temperature. In my case I wanted to be able to increase the ambient temperature in my woodworking workshop from 40 degrees to 65 degrees and I have less than favorable insulation in this workshop, so my desired BTU is 16,359 at 4,794 watts. This heater meets that demand quite nicely.
As for cost, as I mention in the video (link above) the two ceramic space heaters were costing me about $1.56 per evening to heat my workshop. This heater is costing me only about 92 cents for the same length of time. I have immediate savings of over 62 cents per evening of use! Why the huge difference? Because the other two space heaters had to run continuously at combined 3,000 watts for 2 hours to heat the space and then continuously to maintain the desired temperature. The Dr Heater DR966 bring s my workshop from 40 to 60-65 degree in a half hour at 6,000 watts and then only runs intermittently at 3,000 watts to maintain that temperature. Therefore I am using less electricity to heat my shop to 65 degrees and to maintain that temperature.
I have my heater connected to a 30amp circuit breaker and have had no issues with the electrical demand of the heater tripping the breaker. But I am also using a six-foot long 6-gauge cord from the heater to the outlet and 8-gauge wire from the outlet to the breaker and the outlet is mounted directly underneath the sub-panel, so there virtually no distance from the breaker to the six-foot cord.
If the BTU supply of this heater meets your BTU demands I recommend that you get this heater and see for yourself what it's like to have a well heated work space. It's nice!
Here's a link to view the heater I used.
http://astore.amazon.com/wwwdogwoodtal-20
on Jan 28, 2016 | Heating & Cooling
I have a 200000 btu master torpedo heat that has a new , coil,spark plug,eye,fuel valve, the unit has spark fuel but doesn`t fire it looks like it wants to but will not can anybody help me
All torpedo heaters have a mind of their own and will work perfectly for any number of cycles then become contrary as can be. It's usually a slight adjustment of pressure or a tweak of the angle of the cad cell....something simply overlooked. Sometimes just a slight movement of the fan blade forward or backward on the shaft is enough to make it light off. There are some specific tools reuired to get ACCURATE pressure adjustments. I'd suggest downloading a unit specific manual and read it thoroughly.
Dec 10, 2014 | Heating & Cooling
Kerosene works **** diesel seems to not work in my multifuel reddyheater. Why?
diesel is heavier and may not spray through the nozzle. Try diluting it with 25% kerosene and it should thin it out enough to burn
Jan 05, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater keeps going off
check the valve assembly may be bad if not the heat exchanger is plug nothing you can do about this
Jul 21, 2009 | Jandy Laars Lx 400,000 Btu Heater
115000 btu ready heater/ about 3 years old from home depot/multi fuel
I would try cleaning the flame sensor, use a Qtip slightly moist with ispropyl alcohol. it's a rubber boot about 2in. long faceing the combustion chamber with two wires.
Jan 15, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Desa International Reddy Heater 200,000 BTU Kerosene Forced-Air Heater #R200BT Logo
97 people viewed this question
Top Desa International Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Desa International Measuring Tool and Sensor Expert? Answer questions, earn points and help others
