Question about HP Pavilion dv6000z Notebook
Hp dv6000 laptop beeps 4 times n won't display on start up
When i press the power button to on the laptop, there is no display on the screen and it beeps 4 times and the power lids blink.
I had the same problem, i found it was because my RAM stick was installed loose. I removed and fixed it again properly.
Issue was sorted.
Posted on Mar 29, 2010
Hi all
I have had the same problem all I did was removed the ram and put in a 512 mb stick only the laptop then started up all i did then was update the bios turn off the laptop put the old ram back in and it's been fine
hope this helps
Posted on Sep 16, 2009
  • 433 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=ca&docname=c01087277
Also some folks have be getting relief by reseating the memory.
Read the above page from HP
Posted on May 14, 2009
My HP DV6000 beeps 4 times and I end up with a black screen and the power button Flashing
Most likely a memory problem. If you have more than one stick of memory, remove one and try it.
If that doesn't work, remove the other one and replace the one you took out.
Nov 01, 2011 | HP Pavilion dv6000z Notebook
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
Not power on
Your Pavilion DV6000 laptop is the key to your productivity, which is why it is essential that it turns on when you need it. The DV6000 is lighter than comparable models from other brands, and has a large, sharp display. While it has plenty of processing power, the DV6000 can have normal boot problems as well as problems caused by faulty battery packs that were installed in some units. Attempt to troubleshoot the laptop and find out if the laptop is eligible for a new battery pack.
1.Hard reset your laptop if there is no life at all. Unplug all peripheral devices and remove the battery. Unplug the AC cable and press and hold the power button for at least 15 seconds to drain all power. Reconnect the AC cable and hit the power button.
2.Verify that the battery pack is on the recall list if the laptop powers up without it. Fill out the form on the battery pack recall website (http://bpr.hpordercenter.com/hbpr/). You will have to input the serial number of the battery pack as well as a location to ship the replacement battery if you are eligible.
3.Hold the AC cable where it plugs into the laptop and wiggle it while hitting the power button one time. LEDs that come on and off intermittently indicate a faulty power cable. Order a replacement power cable through HP or a third-party vendor.
4.Write down any visual or audio error codes such as LEDs blinking or unusual beeping. The error sequence will be helpful when talking to an HP support person.
I hope this may help your concern.
Jan 22, 2011 | HP Pavilion dv6000t Notebook
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My laptop dv6000 the screen doesnt work so i
does it display on external monitor, if yes then do not worry just change the balesh of the screen of ur laptop it does not cost more,, for more view www.ecwnepal.com
Jul 06, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP DV6110us: 4 beeps, no boot
besides the beeps which indicate a motherboard timing issue. There should be LED blinking codes given on the front LEDs. I will include the blink codes below, but lets try to at least get the system up and running. First, I would like you to remove the RAM sticks from the laptop and just reseat one stick back in the machine. Try to boot with that one stick, if it does not, try the other alone. There have been issues when reseating the ram or re-installing it have temp. fixed the issue. If it does reboot, go to the HP support site, put in your model number of your laptop and download and install an updated BIOS. Below are the blink codes that may narrow down the problem.....
HP DV6000 LED Blink Codes
LED Component Error Condition
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock System board General system board failure
Blink: 6 - Caps Lock/Num Lock BIOS BIOS authentication failure
Oct 22, 2009 | HP Compaq Pavilion dv6110us Notebook
I press the power button, the computer beeps 4 times and stops
Please check the battery. You might have to replace the battery bcos it definately gone bad already.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
My HP Pavilion dv6000 is giving me a long beep then 2 short beeps when i turn it on. I cleaned it out and it worked for a few minutes but when i restarted it the beeps returned
If your system board fixed but come trouble again.
Sometimes flex power cable problem too.
Check out internal your system.
or Mainboard problem. video chipset.
Oct 07, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Plz help my laptop has no display dv6000
More info please. Does it show a boot screen first then go blank? Does it beep when you turn it on? Has your display flickered recently or have the colors shifted?
Jan 04, 2009 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
7,164 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
