Question about NetGear - WG311 - 54Mbps 802.11g/b Wireless PCI Adapter (TGN1001486P)
I cannot connect my laptop computor to my main computor
I dont understand how do this it keeps saying no signal my laptop is a toshiba and it has blue tooth? on it
I and my mnain computor says the same
I have installed 54mbps wireles pci adaptor 32 bit pci wg311
  • 661 Answers
Bluetooth is not WiFi,   they are two seperate technologies.
you need a Wireless adapter 802.11b/g for your laptop,
you would connect the two to each other using an adhoc connection,
If you had a wireless router for your internet you could connect directly to the router, (and then you would not have to have your main computer on for you to access the internet.
BTW if your Main machine is near your phone point (for internet connection) you would not need a wireless card for your pc, as you could connect via LAN cable to the wireless router (make sure you get one with lan ports)
Posted on Oct 15, 2007
  • Gareth Cockram
    Gareth Cockram Oct 15, 2007
    802.11b/g is the STANDARD not a model
  • Gareth Cockram
    just make sure it is the same grade as the router (a/b/g)  g is best
Why is my brand new laptop satellite c655d-s5529 keep on saying toshiba mq01abd032 sata disk device the following hard disk are reporting failure
Take the laptop back "asp" you should not be getting messages on the screen, it indicates device issue and maybe a bigger problem.
Mar 07, 2012 | Toshiba Satellite C655D-S5120 Notebook
I have a Toshiba 3387DB TV and am trying to connect it to my laptop. Tried to use DVI (out of laptop) to RGB phonos cable. Then through a scart adapter into the Scart 1 socket at back of TV. Manual says...
You need to convert the component sync signals into a composite sync compatible with SCART. The red, green and blue signals can be connected through as-is.
Mar 21, 2011 | Toshiba 3387DB TV
My Toshiba Satellite L305-S5921 won't connect wireless or wired to my internet it shows the net works and signals and can be connected to the router but ends up with local or limited service I've reset the...
Try disconnect the router and connect your laptop to the dsl modem. If there is connection then the router may have problems. If the problem persists then go to toshiba service center. They will certainly solve your problem. It might be that there are problems on hardware or drivers.
Jan 30, 2011 | Toshiba Satellite L305-S5921 Notebook
How to use a sony tv as a monitor?
Change the resolution on the second monitor if you ont have the 2nd monitor on your pc , Clik ON DESKTOP PROPRERTY ,SETING'S amd see the 2nd screen rezolution. and make it smaler on the second ,you will be able to keep bouth screen active the monitor and the main screen of laptop.
Jan 19, 2009 | Toshiba Satellite A15-S129 Notebook
Computor wont let me log on its saying my password is wrong i am
A. Ask her what the password is
B. Stop trying to snoop around her laptop.
Dec 27, 2008 | Toshiba Satellite A100-S8111TD Notebook
Trouble networking copier to computer
you might have to set up the nic card in the machine. set it to a static IP address (not DHCP), then ping it from a PC..
If you can ping it, then instalation should find it!
I dont understand " time warner connection to rout both computors thru " ?
you should have.
One broadband Modem...
One Router which all pcs and machine's are connected to...
do ipconfig/all to figure out the pcs IP address, arp -a shows the arp table. determine what IP address to give the machine.
the machine should have a nic card with a light on it, if that light is green when you connect the cable, then the nic card is working.
then proceed to install the drivers to the PCs.
Oct 23, 2008 | Toshiba E-Studio 3511 Color Copier
Toshiba e-Studio 25 and Windows XP
your computer connect to Copier thourgh USB cable port or parellal port .select first communication port.and install software.
Jul 24, 2008 | Toshiba e-Studio 232 Black and White...
Computor with usb wireless 802.11b/g not concecting with net on other comp
for wireless connection you make use of a 'hot spot'.since the sinal is coming fine,get authentication from your provider(a kind of acess)
Apr 14, 2008 | Computers & Internet
Computers & Internet Logo
168 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
