Question about Gateway Tabor 3 (4000532) Motherboard
Update bios........ but i do not now what is the brand of the motherboard please help me important
  • Dick
    Dick May 11, 2010
    If it is a Gateway computer, Gateway has any bios updates there might be. Search the Gateway site for your computer's model number.
    What issue are you hoping a bios update will solve?
    Brigadier General:
  • 10,406 Answers
Updating with the _WRONG_ BIOS-update can _kill_ your motherboard. If you don't know how to do it _CORRECTLY_ then don't it, or get a certified technician to do it.
Posted on May 14, 2009
2 Suggested Answers
Pravin_jha
  • 76 Answers
SOURCE: ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Posted on Jun 15, 2009
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
Tip
How to tweak your computer
Step 1
Back up important files. This includes impotant datas stored on your computer
Step 2
Update the firmware of your computers BIOS. Also update or patch your OS to the lates update and even your hardware devices must be updated as well.
Step 3
Also before proceeding ,remember to get a BENCHMARK test program that will help you see the changes and also monitor the temp. of your processor after overclocking
Make sure that your BIOS is also set to shutdown once illegal voltage or temp. will be detected
Step 4
Ensure that the CPU FAN is clean and is still calibrated to the right rpm
Step 5
Power on your unit ,hit the hotkey to access setup.On the BIOS go to ADV. CHIPSET option.Then look for"clocks, "frequency/voltage control" or "voltage options." This will look unique on each brand of computer.You can overclock by modifying "CPU bus frequency" or "CPU FSB frequency." Increase this value slightly. In some cases, you will be able to increase your "CPU multiplier" through the BIOS.If your BIOS has none of these options,your motherboard is not capable of overclocking the processor.
Step 6
You can also try overclocking your MEMORY AND VIDEO speed. Some motherboards have this options on the BIOS as well
Step 7
You can consult your motherboards manual to know the operating voltage of your cpu or type in the model of the board on yahoo or google.
on Dec 19, 2009 | Computers & Internet
I have ASUS P4BGL-MX 845GL (AS04P4BGL-MX) Motherboard that BIOS version is ( 05/06/2003 - I845GL/ICH4/IT8708-P4BGL-MX) now i want to update my BIOS. if it is possible plz help to me. how to update this.
HI
you can update BIOS from BIOS updater.. BIOS updater is tool which is used to update bios on newer version...
try to download this tool from your motherboard manufacturer site..
caution:-
do not turn off your PC while updating your bios...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Como actualizo la vios de mi PC Chips V21G
Hello you can download the upgrade here:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=384&CategoryID=1&DetailName=Bios&MenuID=1&LanID=2
IMPORTANT NOTE:
Please read the notes carefully before updating BIOS.
1. Do not update the BIOS if the system is running fine. Unsuccessful BIOS flash may cause the system fails to boot up. The manufacturer is not responsible for any BIOS flash failure.
2. Make sure your M/B PCB version number first, and then read the updated description & special note carefully to check if the new BIOS version patch pertain to your current problem.
(How to recognize the M/B PCB version)
3. It is recommended to use the updated flash utility included in each BIOS download package.
(How to use flash utility).
Good luck
Jul 21, 2011 | PC Chips V21G (V1.0C) Motherboard
I want to update my P4BG-VM asus m.board bios update
Please go to this site and select your operating system. Your bios update options will be listed under the bios drop-down. Hope this helps.
May 22, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I have a sort of bios i think it is intel motherboard and i want to get my bios updated what to do ?
if you have a working motherboard you should have a bios not a "sort of it". (just wanted to clarify). bios is a chip/sofware built into your motherboard that helps during the booting process and intervines in between your sofware and your hardware communications.
if you want to update your bios (also call flashing your bios) you need to have a good reason for it, (to fix a problem known to be your bios or to enhance features or performance) in other words if you just want to upgrade your bios for the heck of it it's better not to do it becuase if something goes wrong your motherboard is totalled. (the rule of thumb to apply in this case is: if it's not broken to fix it.)
now if you do have a valid reason to do it. there are different ways to do it. the first thing to do is to find out your motherboard manufacturer or the company that supports that motherboard installed in your system and have details like the model number, the number is usually found on the printings rigth on the motherboard (biggest numbers/letter combination on the motherboard. sometimes you can get those details from the pc manufacturer if the motherboard came installed in brand system.
the second thing you do is to go on the internet to the mb's manufacturer website or pc manufacturer website and look for the model of your pc or motherboard under technical support>drivers and dowloads section (the names and locations may change).
once you have the package downloaded you need to look for instructions on how to proceed, as the way to flash your bios may differ.
usually you would burn or create a startup disk and then you would boot from the disk and run a procedure to execute the bios update. one important consideration is to make sure your system is powered at all times during the flashing process and hopefully your system is surge protected as if the process fails you may need to replace mb/system.
if you want to provide mb details or system details we can help you find the bios update you may be looking for.
Mar 23, 2010 | Intel Motherboard
Bios file of d865gvhz
Hi, Before you go for updating BIOS, read the important note here.
The BIOS update file for your Intel motherboard is here.
Feb 23, 2010 | Intel D865GVHZ Motherboard
ACPI Compliant
Jun 15, 2009 | Computers & Internet
BIOS update for Asus A7V-ML
For branded computers like HP, Compaq, Dell the only place you can get the correct bios updates would be your computer manufacturer website under the support link. These companies do not use industry standard motherboards so it could corrupt your system to update from any other source. Hope this helps.
Apr 27, 2009 | AMD Asus A7V-ML Socket A MicroATX...
It takes too long at start up
run defrag under
"start",
"all programs",
"accessories",
"system tools"
"disc defragmenter"
Jan 28, 2009 | Intel 865G Motherboard
Gateway Tabor 3 (4000532) Motherboard Logo
150 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
