Question about Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner
Slow read speed
When I place a CD, data or music, or a DVD into the drive it takes a very long time for anything to happen.
With music disks it comes up quick enough but when i play the music its really choppy and poor quality. this has nothing to do with the disks, ive used these disks before and they work fine on other computers.
DVD's have the same problem, they play with a really poor FPS.
this problem has only started recently, had no problems before this. firmware is latest, driver version is 5.1.2535.0
Running XP pro, service pack 2
intel core 2 duo 2.13 Ghz
2GB ram
geforce 7600GT
  • 2,427 Answers
I suggest you first restore your computer to a previous date when the drive was working propperly *USE SYSTEM RESTORE*
If that doesnt help Run an ant virus scan and Anti spyware scan.
Check the cables connecting the drive in your computer for defect of age and replace if necessary
Check the drive on anoter pc to see if you get the same proplem , if you do then you will need to change the drive as its life span is ending
If it works the something is wrong with your computer, backup you data, Format the hard drive and reinstall windows , your drivers and software and check the drive to see if its working.
if no then the problem is hardware. you might want to considering upgrading
NB.. defragging you hard drive before formatting might help
Posted on Dec 30, 2007
My CD drive on my computer works sometimes and doesn't work other times. It will read data cd's more often than music cd's.
Some CD drives don't read all types of disks. For example it may not read DVD-R disks but will read DVD+R or Bluray disks. If you provide the model number of your drive I can give you a more detailed answer.
Mar 09, 2011 | E-Machines eMachines Desktop PC
My cd/dvd drive will not burn cd/dvd's properly. it goes through the motions, but the discs come out as blank, i was able to burn cds at 2x speed, but that was it. any movie, or anything else will go...
ok..
what kind of application you use for burning??
try it again then double check if you really choose the right path of th drive you want to use as burner..
then you are sure that you burn the music as audio cd not data cd..as well as the video cd not data cd..
because if you burn data cd only computers can read that.. not your aplliances like for example your dvd player,cd,etc.
Feb 08, 2010 | Computers & Internet
How do I Install my LG GCC-4320B
ok take this step to connect the cd 0r dvd drive
To install an external DVD drive:
  1. When purchasing a new drive be sure to understand the many formats available: DVD, DVD+R, DVD-R, DVD+/-R, DVD+/-RW are a few for example. More recent technologies include DVD-DL, HD DVD and Blu-Ray Disc. A decent DVD drive should be able to read and write both "+" and "-" technologies and also support recordable (R) and re-writable (RW) technology. Essentially look for a DVD+/-RW drive if you plan on recording DVD's, or just a plain DVD drive for reading DVD's (movies, games, etc). There are a variety of speeds from 2x-16x for a wide spectrum of users and needs; higher speeds will record faster.
  2. If you have a USB connection on your computer you can use an external drive. The advantage to an exterior drive is that you can use it on other computers as well.
  3. To install an external DVD, just follow the instructions provided with the drive.
To install an internal DVD drive:
  1. Look for a DVD with the letters RW on the box. This is so you can read disks and record them as well. Make sure the speed rating is 16X and that the DVD is dual layer so that it takes care of the latest technology.
  2. Read the instructions that come with the DVD. It may require you to load the provided CD software before installing the DVD player. Leave the disk in your CD ROM player for the rest of the procedure.
  3. Disconnect the power cord from the back of the computer (goes to the wall socket of your house.)
  4. Open the case of the computer.
  5. Locate the hard disk or CD drive. Most have two connections and can only be snapped in place one way. One connection is for data and one for power.
  6. Check to see if your computer mounts the DVD/CD ROM drives from the inside or if they are pushed through the front panel (you may have to remove the plastic panel on some models.)
  7. Carefully remove the plastic “knock-off?? cover on the outside of your computer. Make sure you do this only when you are ready to install the DVD drive.
  8. Slide the DVD drive into an empty compartment or bay. If it’s an older computer you can secure it with screws that come with the DVD drive. Many newer computers have spring clips to secure the drive in place.
  9. Connect the DVD drive to the data cable. The data cable is wide like a ribbon and is also called a ribbon cable and has a red stripe on one side. There are two or three connectors on the data cable. One is connected to the circuit board, one is connected to your CD drive or hard disk and one in the middle (optional third connector) is usually not connected to anything. Use the middle connector for the DVD drive. If your data cable only has two connectors replace it with the one that is generally included with the new drive.
  10. Hook the DVD to the power connector. This is a normal round looking cable. There are usually several power connectors in the computer.
  11. If you don’t have an available power connector, then you can buy a “Y?? connector to hook up to the existing power cable. Unhook the power connector and hook it to one side of the “Y?? and hook the DVD to the other side of the “Y??.
  12. Re-assemble the cover and plug the computer back in.
  13. When you run Windows up it should look for the drivers for the new DVD player and automatically locate and load them from the CD ROM that you left in the CD player from the first step.
thanks
ok bye...........................
Nov 18, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
I had to download all kinds of drivers to get my computer to do basics like viewing movies hearing music and finally burn music now i learned i can only save data(lots of songs at one time) or make a cd on...
cd-r80 are for music. Your best option is to buy a program like nero. I assume you are just dragging and dropping files to burn them right now. dvd's are more meant for backing up data or making movies because they hold a lot more data then a cd. Are you able to burn disc's at all? Just like all things involved with computers it can get complicated real quick.I hope this helps a little and if you have more questions let me know
Thanks,
Lee
Nov 05, 2009 | Dell Inspiron E1505 Notebook
My computer is slow and the is not reading or burning CD/DVD
Slow computer problem would be different then that non reading disks. Slow computer could happen in many cases, a virus is taking up all the memory, or defragmented hard disk, programs that required more memory and cpu speed. CD, DVD could fail to read due to loose cable, BIOS setup or damaged drive.
Sep 16, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
Disc driver not reading discs
Can be several reasons
1. Disk is upside down
2. Lens is durty. Use CD/DVD cleaning disk
3. Disk is recorded in higher speed than your driver can read (for instance reading speed is 16, but disk is recorded on 24).
4. DVD drive is damaged or not connected properly.
Good Luck
Dec 10, 2008 | LG Computers & Internet
DVD RW Drive
Vista sucks. However, delete your drive and change the IDE cable. Also, put the drive onto another IDE channel so it re-initializes your drive - winodws data bases a drive when it has more than 5 DMA errors and clocks its speed down to PIO - very slow
Jul 22, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
DVD BURNING : TAKES TOO MUCH TIME AND CPU USAGE GOES TO 60%
Based on the laptop model you have listed, I am afraid to say that there is not much that you can do about the time it takes to burn DVDs. Computers often come with re-writeable (RW) drives that have different speeds. Thus, on older laptops or desktops, the drives are very often slow and will take a large amount of time to burn a full DVD. As for the CPU usage, writing data from a hard drive to a DVD or a CD is a very memory and performance heavy task, especially on older computers. You can attempt to free up resources by closing as many non-essential programs as possible prior to burning a DVD... but that will not dramatically increase the speed. Not using the laptop for other purposes while it is burning a disc may also speed up the process.
Nov 01, 2007 | Dell Inspiron 2200 Notebook
Open Questions:
Pioneer DVR-111D (DVR111DBK) DVD RW Dual Layer Burner Logo
69 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
